![]() | Home > Puma (Tdci) > EGR Options |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
just an update-
the 110 is going into Chris (CSK) tomorrow for an upgrade to an alive tune w/ EGR switch off. Thanks must go to Chris @ CSK and Gary @ Alive for their great advice and help. Cheers everyone, will report back results tomorrow! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20948 ![]() ![]() |
You'll be amazed David once completed trust me.
You'll have a smile a mile wide once complete. ![]() |
Great
![]() The monster tune was a good first step but this should be a great improvement too ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
The EGR shut down in its self will help a lot of things across the board. MPG, idle and engine running smoothness and quality.
Power delivery etc. That's before you get the actual tune it's self. A stage one tune is around 155HP. |
Great
![]() ![]() I bought myself a blank which came today, is it worth fitting that too? If so should it be done by Chris before he remaps it? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
My opinion which is shared by those in the know would be fit it....
It's the only way to be 100% that nothing is getting by and is the engine / calibration is set so as not to expect any exhaust gases or by product of the egr passing then it's the only way of making sure all is within expected parameters. Also if you're having your engine re mapped I presume this would be a complete new file.....if that's the case does the ecm receive generic information which then needs to be 'tailored ' to suit the injectors and pump ie a injector and pump learn needs to be undertaken or is it possible to do a remap which somehow leaves the injector and pump information in place and kind of works round it??? |
It's a complete new file.
And yes, get Chris to fit the blank at the time it's tuned. The two really need to be done at the same time. |
So presumably any of the bolt on boxes or remote tunes will need to go through the pilot learn process for best results?
Which kind of backs up what has been said before about the tune boxes not being the best option? |
That'd be a question a tuner would be best placed to answer rather than myself.
However, I'd never personally have one of those tuning box things. |
So an update-
Went to see Chris & get the Alive remap with EGR delete yesterday. Couldn't be happier! Light off, ticks over better etc. And then the Alive map really is a step up, not necessarily more powerful as I asked for a 'middle of the road' type map, but just smoother and torquier through the whole range. Beautiful! How it should've come out of the showroom. Limited removed is nice too, and the EGR is also physically blanked so as to be extra safe. Thanks again to Chris and Gary!! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
