![]() | Home > Puma (Tdci) > Slight Header Tank Leak |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
I have had my Puma 2.4 for a month now and noticed that the header tank is loosing a little coolant from the cap, so tightened it up after topping up and it still has a slight leak (slight dribble down the side) .
I have bought a replacement header cap from Land Rover but it still has a leak, but less. If you wipe a tissue round the cap there is a slight red stain of coolant. The manual says “Make sure the cap is tightened fully after top up completed”. My question is how tight should it be? Just hand tight or as tight as you can get it? I have in the meantime ordered a new header tank just in case the screw-thread is fubared. BTW the temperature gauge is as expected after 60 miles, and the car is not overheating. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2674 ![]() ![]() ![]() |
that cap is crap, replace it every year, and no more coolant loss
![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Ditto .... And on this occasion a pattern part cap seems to work better than the genuine article 😉 Guns and Landrovers .... anything else is irrelevant.
