![]() | Home > Technical > Clonk clonk |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052 ![]() ![]() |
Drive flange
Diff pinion flange Rear axle ball joint Wheel nuts Drive flange bolts. All worth checking Andy |
Velo-felo Member Since: 18 Sep 2014 Location: Forest of Dean Posts: 19 ![]() ![]() ![]() |
Drive flange sounds very likely as its that kind of clicky clonk... If that makes sense.
I see a lot advertised as upgrades from OE, any one have a recommendation of choice? Thanks , Steve |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
I did mine very recently and went for Bearmach OEM. http://www.defender2.net/forum/topic28138-105.html
They were a nice tight fit and so far very happy ![]() Self confessed mileage hunter ![]() |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I changed my rear prop uj's at the weekend to cure a clonk I was getting on pulling away and lifting on/off he accelerator. When I tried to move the prop by hand I couldn't get any movement at all, it wasn't until I lay down beside the defender while the GF reversed/drove forward up and down the drive could I hear the prop moving.
Once I had stripped the rear prop off it was very obvious that was the problem and I am glad I did before the prop fell apart! |
