![]() | Home > Technical > Bracket on 110 front diff |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
It's to offer 'support' if it gets knocked, to stop the rod bending. If yours has been rubbing, something ain't right, or someone has put thicker rods on and not binned the 'bracket'. QRZ 2e0vpf
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 860 ![]() ![]() ![]() |
Just to try and prevent any 'bendage' if the off-road stuff gets too rough. As said, if the track rod is rubbing then it must be bent. I have just binned mine after fitting a Simmonites Dam bar over the original tube.
Autolycus Member Since: 16 Oct 2013 Location: Derby Posts: 6 ![]() ![]() |
Thank you both, very much.
I'll check the tube for straightness, and I'll either apply BFI or add one to my next order. Can even BP get these wrong? Kevin |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17919 ![]() ![]() ![]() |
I think you'll find the setscrews are UNF not BSF (60º thread form not 55º).
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
It could be the angle of the photo, but that bracket looks as if it has been bent downwards which would probably account for the wear on the upper inside face.
That is how they are made, and it is a chunky piece of extruded aluminium, I expect the bolt heads would snap before the bracket bent at that point. |
Thanks for the further comments.
The bracket is "bent" on its top face, but, as ILOS says, it looks as though it was made like that. I'd have expected UNC or ISO metric threads, but they're definitely 3/8 BSF, 20tpi. I wonder if the diff housing has had to be re-tapped from 5/16 or M8? One of the mucky-trucky's many mysteries. Kevin |
I've just looked them up on Microcat and you are absolutely right, they're 3/8" diameter x 20tpi, 5/8" long, BSF setscrews. I had naively thought they'd be UNF since the propshaft bolts and the studs that secure the pinion housing in the axle case are 3/8 UNF.
I wonder if the Defender is the last production vehicle in the world to use Whitworth, Unified and ISO thread forms all on the same component! |
