![]() | Home > Technical > Show me your Anderson Connectors. |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1181 ![]() ![]() ![]() |
THanks for the info and photos guys
I will be fitting mine to my seat box. Cheers G My confidence has been writing cheques that my abilities can't cash for years. |
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 ![]() ![]() ![]() |
Here's mine - on the seat box
Here's anolther. Must be just in the marine environment they corrode. Little wonder I have no faith in them. This one had only been fitted for about three months.
![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2712 ![]() ![]() |
TBF anything in the marine enviroment will corrode due to the slat in the water. I very much doubt there will be many on here who put their pride and joy anywhere near salt water. I know I don't.
I'll be fitting an anderson to the front of my 110 when I can find time to sort it out and the pennies for the cabling. 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Looking at that photo that left hand contact appears to have all the silver plating removed and to be suffering from copper 'corrosion or oxidisation. Presumably left where salt water or spray could get at it?
Have not heard of anything like that in the 4x4 world. OK a Defender cab might get moist but not that moist and not in corrosive content. Personally I do not see any issues with using an Anderson connector on a Defender. Their are genuine Anderson connectors, there are good quality high current DC connectors such as Rema and then there are the cheap copies. If tempted to buy the cheap copies have a good look at the contacts. On genuine Anderson connectors the contacts are smooth and silver coated. On the cheap copies the surface can be extremely rough, lumpy, pitted etc from new. This means that the actual contact area is much smaller and that arcing might occur in between the contacts which is not good news. Brendan |
![]() Remind me never to buy any second hand parts from your part of the world. |
No need the North is flooded with second hand parts from Defenders apparently. If not it should be according to Landywatch.
http://www.landywatch.co.uk/index.php/stolen-vehicle-maps/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Anderson leads are used externally for powering tail lifts on hgv's,exposed to all weathers, road spray and driver abuse,I would expect an anderson lead inside a Defender to last forever Pov.spec,ftw. 2006, 110,TD5.
