![]() | Home > In Car Electronics > Tablet/iPad Mount |
| redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243
Hi Lambley,
iPad is solely used with Viewranger when off road by passenger. Sat nav for all else. Do use it when stationary to have a look at emails such as this during work time. Steve |
Hi Wildcard,
The griffin is a great addition. I'll measure it later and post then. Steve |
| Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060
No offence taken. I think the lobby for having additional or more precise navigation when not wishing to be directed onto the major routes, and for greenlaning, has been strongly voiced. However, your point is extremely relevant and important, and I fully understand your concern. The motorist is already dangerously distracted by the features on many modern production car dashboards, and things are not improving. How often do you come across a full frontal collision between two cars on a straight piece of road these days, and wonder how the hell it could happen? As has already been pointed out, the iPad is a great bonus for the passenger too. But the whole communication package, satnav, iPad and mobile phone has to be used in a responsible manner. The brekes, and the chassis response of a Defender under braking means we have to be more attentive to begin with. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
I've got a 7" Snooper permanently fitted in my Defender which doubles as a Europe wide SatNav and a 50K:1 Ordnance Survey display. If I'm running 25K:1 OS a larger screen would be very desirable. I'm thinking of buying one of these to take my 10.1" tablet.
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582
We use the Ram Mount kit. The X Grip will take tablets in protective cases. Or there are the tab tite type holders.
iPads can be useful on the passenger side of the vehicle but have to be used responsible. Not to be used by the driver when vehicle is in motion. Brendan |
| ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572
Hi Stephen,
Sorry for the delay in getting back to you re sizes. The Survivor case has inner and outer sections, the rubber parts has sections of the edges where it may be possible for the holder to fit. On the rubber covered edges the thickness is approx 20mm and the sections with no rubber are approx 15mm ( sorry about the "approx" but I'm not at home so don't have acces to my vernier gauge!) As I was typing this my bracket has just arrived from Amazon, and no it doesn't fit out of the box, even after removing the rubber padding, but I think my idea from my previous post will work, the positioning of the support arms means that it will have to go over a rubber covered section of the Survivor so some surgery will be required! When I get home and have access to my tools I shall get it modified and post a photo on here. Btw Griffin are a great company to deal with. i also have a survivor cover for my iPhone, I put it into my pocket with some keys and scratched the screen cover (doing it's job). I contacted Griffin in the US to ask if they could advise how to polish out the scratch, they asked for a photo then promptly sent me a new cover free of charge! Chris 2010 Defender 110 Station Wagon, Santorini Black. |
Chris,
for sure you need to modify the tablet holder to be able to get around the 20mm of the Griffin. As you suggested, cutting the tops of the claws is the first stage. I would leave the rubber inserts in the claw and use an aluminium profile cut to length to replace the missing tips. Something like this....
could look like this installed....
Stephen 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
Hi guys
At last my photos, can't seem to load them into this message but they are in my gallery. The iPad is held pretty firmly and the case does a good job of cushioning but the problem is the stalk - it waves about all over the place! So not much use. I think I will be going with a RAM system, pricey but looks like it will do the job. Chris 2010 Defender 110 Station Wagon, Santorini Black. |
Chris, post a picture of the bracket that the stalk is mounted onto. How have you installed it? You appear to have the same product as I have. The stalk is rock solid on mine. Unfortunately the base bracket, although made of stout 5 mm steel, does have a little bit of "spring" to it. If you donīt tuck the forks right under the seat rail (as far as it will go) you will turn the bracket into a spring, and the stalk amplifies the movement.
As I have fitted it, unmodified in my Defender, it has served us well on many trips already. I have nothing against the Ram mount. However, if you read up about them in the net, their users deal with the same problems with the stalk. The stalk solution only works if the base bracket is absolutely rock solid and correctly mounted. Stephen 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
Hi Stephen,
Thanks, I'll have a look at that, I think mine does stick out quite a bit from the bolt, I'll re-position it and see if it helps. The RAM mount I was thinking of would be attached to the grab handle. Chris 2010 Defender 110 Station Wagon, Santorini Black. |
Chris, thats how I fitted mine to begin with, experiencing the same issue you described. Once you push the bracket in fully the difference is remarkable.
Because it is difficult to access the seat rail bolt once the bracket is tucked in there, it is tempting to slide the bracket forward...and then it turns into a spring! I used an 8mm allen headed bolt and a ball type driver to tighten it up. A very compact socket might work on original LR hex bolt, too. S. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
Hi Stephen,
Same with me it was the difficulty of tightening the bolt when pushed fully home. I've had another go at it and pushed it right in under the bolt and managed to get a spanner on the original bolt to tighten it, I did also manage to find, like you, an allen headed 8mm bolt in case I couldn't tighten the original bolt. I shall take her for a run tomorrow and see how we go. I shall report back! Chris 2010 Defender 110 Station Wagon, Santorini Black. |
Still waves about badly even with the slot fully engaged under the runner bolt, as you say, the problem is the mounting bracket, I can see it flexing at the bend, the actual flexible stalk doesn't seem to move, perhaps it is just too long and the leverage on the bracket is too much, though I must say, it is a pretty solid piece of steel!
Looking at the RAM mount on the grab handle, it appears to be a more rigid system so I shall investigate further.....! Chris 2010 Defender 110 Station Wagon, Santorini Black. |
| Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692
I bought this last night for Ģ24-00 http://www.amazon.co.uk/Arkon-Floor-Mount-...iPad+Air+2 as could not justify the amounts that Ram want to charge. Will fit over the weekend and will provide feedback in a few weeks.
Cheers Steve |
