![]() | Home > Technical > Huge Fuel leak |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327
2 pipes are diesel (in and out) and the other 2 pipes are coolant from the engine. Of course, the 2.2 that doesn't have the cooler don't have the water pipes. Craig Rogers
2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
| LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233
Dealer mechanic found one of the fuel lines detatched as X Isle suggested. He also suggested that as the 2.2 has a low pressure fuel pump this would potentially allow vehicle to run normally therefor not giving a warning! He did say there was no reason he could see why the hose had detached.....
Awesome!
Glad it was as I thought. I bet it just was never put on properly and finally decided to pop off. Did you find out if you have a cooler or just the pipes? Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
entreq plate on mine...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
IID Pro MV License |
I don't quite understand the Entreq plate.
It's supposed to protect both the oil filter and fuel cooler. However, in that 2nd photo you can clearly see oil filter housing? So it looks like things can still be thrown up from the front wheels and hit the oil filter. I've got the D44 fuel cooler guard and I'm going to make my own oil filter guard. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Just bought an Allmakes one from MPS
Thanks guys. |
| All times are GMT |
