![]() | Home > Puma (Tdci) > Front end sag |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I had the same issue with my Tdi when I fitted a winch to it, to raise the front back to normal height I fitted standard rear springs to the front ( standard rears are the same as heavy duty fronts). 2005 Td5 90 XS
Steve |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2482 ![]() ![]() ![]() |
Fit a rubber isolator: ANR2938 or RBC100111 Puma 110" SW
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Try fitting standard 130 springs!
