![]() | Home > Maintenance & Modifications > Stainless steel EGR blanking kits |
| Robofarmer Member Since: 17 Mar 2010 Location: cheshire Posts: 88
No light steve ! but this method does need alot more testing. i agree to machine a chunky block of steel with an induction port and pipe would work. I was trying to come up with something that would not get noticed at dealer vists or as easy as one of my blanks to take out ex 1988 defender 90 ,td ex 1970 series III |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Could you "move" the day? anyway I PM you my mobile number and email ..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
Thats fine dgardel like i say i,m in italy from the 14th until 26th ,ish ex 1988 defender 90 ,td ex 1970 series III |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067
Tim,
I fitted the 10mm plate yesterday and I had to loosen the bolt on the right side of the engine to get enough room to pull out the previous plate and fit in the 10mm plate. I haven't been out on the road to try it out yet. Hopefully the light won't come on when I do! I will post again later once I've done some miles. Daz110 |
| Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92
thankyou das i will also post a reply when i get some more km up it will be about 2 to 3 week cheers
My MIL light has now lit after fitting 10mm blanking plate and traveling about 600 miles
Time to try the 12mm plate I think? |
hi daz iam still on the 16 mm done about 500km i have safrai snorkel seams to be going very well the fuel is better i was getting about 10.5 to11 liters per 100km am now on 10 will try a smaller one in about a 4weeks cheers tim let us know how the 12 mm gose
| BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537
Jumping in on this conversation, I have a 110 Stormaway XS utility that is almost the twin of the one pictured in this conversation. I have had the 12mm plate fitted for about the last 500 miles and my light has now come on, so will move up to the next size when I get a chance. Also have BAS remap, Safari Snorkel, ITG air filter, Allisport hoses and straight through centre pipe...
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Bigfog,
I have a similar set up to you and am running 10mm have no MIL light, (it did come on once with a P1103 code which I reset and has not reoccurred) it may just be a one off???? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Could well be, but how can I clear the fault to see if it happens again, all I have is the BAS mapping tool which I understand can read the codes, but not sure if it will clear them as well - short of that the car has gone beautifully since the plate went in. Thanks for the input.
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
The BAS interface mapping tool will clear codes
Many thanks Fekete, I'll give it a go, it's got to be easier than changing the plate out, especially as it's dark and wet outside now.
Just go in to read codes when the codes come up just scroll down to clear codes
Looks like I will try that as well.
