Home > Maintenance & Modifications > Nakatanenga grille- Badge
Landi
Australia
Hi there,
I have the heritage grille from Nakatanenga on my puma with aircon, and wondering what the best way to fit a badge on it is? Ideally I'd like to put an old black and white series one on there, but unlike the genuine heritage grille, this one doesn't seem to have a plate to mount it. Any advice would be great! Cheers.
http://www.4x4overlander.com/product/nakat...l-black-2/
Post #401604 24th Feb 2015 7:27am
leeds
Is it the type with two bolt holes in?
If so would suggest a back plate with matching holes and lightly clamp the grille between the badge and back plate.
Brendan
Post #401620 24th Feb 2015 9:22am
nakatanenga
Germany
Hi,
just bolt it through, no problem. WANTED:
SII or SIII in max 1.5k
Post #401635 24th Feb 2015 10:27am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I was faced with a similar problem, and wanted sonething clean and simple to mount the modern LR oval emblem.
Cut a backing plate, the same size as the badge.
I used 6mm aluminium, rounded off the rear edge, sanded and polished it.
Drill two holes in the plate spaced to match the openings in the grill. Cut 6mm threads into the aluminium.
Using a couple of (10mm) rubber grommets pushed snugly through the grill openings, two (stainless) 6x12mm bolts and large washers you can now bolt the mounting plate to the grill. Double sided tape the emblem to plate. Done!
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #401642 24th Feb 2015 11:08am
Landi
Australia
Thanks so much for the tips. I'll give it a go and report back! Cheers
Post #401652 24th Feb 2015 12:10pm
leeds
Looks a neat job Wild Card Thumbs Up
Brendan
Post #401653 24th Feb 2015 12:21pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Have you got one of the Ozzie grill badges to go on?
[URL=][/URL]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Euro-Leafing to infinity and beyond.....
Post #401675 24th Feb 2015 2:19pm
Wild Card 90
Brendan
Thanks Brendan.
Stephen 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #401687 24th Feb 2015 3:01pm
Landi
Australia
[URL=][/URL]
I've got this one. Similar though
Post #401894 25th Feb 2015 1:28am
Landi
Australia
Sorry not sure if the image is showing up. It's in my gallery I think.
Post #401895 25th Feb 2015 1:36am
Landi
Australia
So I'll make up a backing plate of similar size to the plaque, drill holes to match, and then should I rivet it (from the back or front), bolt it, or just use a couple of screws from the front?
Post #401899 25th Feb 2015 4:44am
Wild Card 90
With that classic Solihull badge, I would bolt from the back (large washer and a grommet in between) and fit dome nuts from the front
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #401909 25th Feb 2015 7:55am
Personally with the classic - I'd pop-rivet the badge on, it would stop scumbags nicking the badge
Post #401913 25th Feb 2015 8:24am
ericvv
Post #401923 25th Feb 2015 9:04am
