Home > Puma (Tdci) > Auxiliary Fusebox Mounting Advice
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Hi all, I'm hoping someone with more brains than me has come up with a solution to my problem.
I currently have an additional Fusebox located next to the battery under the seat, but would like to fit a 2nd battery and hence there would be no room.
On my old 90 I just fitted it behind the passenger seat on the bulkhead - here the only place I can see on my 110 utility is to put it at the side of the back door. Not a major issue but means a lot of expensive large cable initially and long runs of smaller cable to the front for switches etc.
Anyone got any ideas? Thanks Smile Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #401319 23rd Feb 2015 1:01am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I put mine in the driver's seat box, leaving space for the future additional battery in the passenger's seat box.
Post #401321 23rd Feb 2015 1:51am
VeeTee
Netherlands
I have made an "under cubbybox" where all additional electrics, relays and fuses live. As a bonus the armrest is now at the correct height. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #401326 23rd Feb 2015 3:47am
ozzie1989
Thank you both Very Happy
VeeTee - Do you have any pictures, that sounds like an interesting idea Idea Now: 2010 2.4 TDCi 110 Utility Wagon
Post #401397 23rd Feb 2015 3:05pm
I have a 2.4 with twin odyssey pc1500's - a genuine bluesea 6 or 12 way will fit on top of batteries, bluesea copies wont
HTH
Post #401460 23rd Feb 2015 7:05pm
TJ101
Put it with most of the rest of fuse's live Under the right hand seat
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #401461 23rd Feb 2015 7:07pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I did a bit of a write up on mine http://defender90xs.blogspot.co.uk/2014/01/under-cubby-safe.html http://defender90xs.blogspot.co.uk/
Post #401462 23rd Feb 2015 7:11pm
VeeTee
Netherlands
I have just put some pictures in my Gallery.
Under the driver's seat (LHD vehicle) there is a second battery with VSR (Cyrix Voltage Sensitive Relay) and Cetex battery charger (the Webasto Air Heater lives under the passenger seat). The additional relays in the under cubbybox are connected to the auxilliary battery via the main switch. There is also a Timer Module for the heated windscreen and two extra sockets at the back of the box. At the front of the cubbybox the 7" screen for a dual camera setup (front and rear) is mounted.
Still some room for more toys left ... Laughing Cheers, Vincent
MySite
Post #401486 23rd Feb 2015 7:58pm
ozzie1989
To all,
I can't thank you enough for your ideas Smile
I really like the idea of putting it under the cubby, although I will probably make my own frame etc. I also love the idea of re-locating the existing electronics there from under the drivers seat for a bit of added comfort when wading.
I'll add some pics hopefully when I make a start Smile Now: 2010 2.4 TDCi 110 Utility Wagon
Post #401627 24th Feb 2015 10:01am
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
There's an outfit in Australia that sells a version ready-made for this...
http://www.expeditioncentre.com.au/online-...exbox.html
It regularly gets positive write-ups on AULRO
Post #453826 10th Sep 2015 4:37am
leeds
There are various choices with a dual battery setup
1) Fit on top of battery clamping bar. Please note for this application you are better off with the slimmer Blue Sea fuse box rather then some of the other makes available. Space can bt tight so be careful with height of battery/fuse box combination.
2) Fit in drivers box. Best done with a right angle brackets which we can help with.
3) Fit inside cubby box
4) A Nakatanenga under cubby box safe. Would need various extra holes drilling in for cable access
5) A GMB electrical box fits under cubby box. This is designed as an electrical box. Box has prepared holes for cables which you just punch out and fit a grommet too. Can get internal dividers etc A purpose designed electrical box.
Yes we can help with supplying the above items.
Brendan
Post #453876 10th Sep 2015 10:15am
Vitesse
HI,
I fitted my fusebox (in fact, the same box!) exactly as TJ101 under the drivers seat. Works really well and managed to run cables using flexible conduit where needed.
good luck.
Brian. 2015 90 XS Santorini Black
Post #453905 10th Sep 2015 12:40pm
