Home > Puma (Tdci) > Adding Oil in diesel and why?
Page 2 of 3 <123>
landy andy
In the same way land rover decided that the chassis doesn't need waxoil, or any other protection, and the engine should have a restricted amount of power? Question
Andy
Post #401281 22nd Feb 2015 10:46pm
mick
ken wrote:
Never been convinced with this one
Me neither shell or BP ultimate for me and every so often millers power max Thumbs Up
Post #401285 22nd Feb 2015 10:51pm
bell-auto-services
200+K miles on a puma engine with regular servicing with the recomended oils using any diesel available at the time of needing to fill up proves nothing more is needed in the fuel I personally feel.
Post #401286 22nd Feb 2015 10:51pm
munch90
I agree maybe its not needed , but are remaps needed Whistle
or does it improve what is there , same as remaps
not knocking you or remaps , think you do a very good job and they are good improvment
Post #401291 22nd Feb 2015 11:04pm
bell-auto-services
I just cant see the benefit of spending more money on fuel adatives to run the car for no more or very little gain than just putting a good quality diesel in and no adtivies at all.
I know if does not give more power with or without it as ive tested that quite a few times now.
Post #401295 22nd Feb 2015 11:14pm
Green Machine
Out of interest Pete, have you ever done a test with Millers EcoMax? I run my Td5 with it in every tank because it runs a lot quieter and smoother. I don't know if it claims to have a power benefit, but would be interested in the result if you've tried it? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #401297 22nd Feb 2015 11:19pm
bell-auto-services
Not on the dyno no, I tried some Millers a long time ago in the past in my own car but it was not ecomax from memory.
One thing I do remember is when I went to France about 10 years ago, their diesel from the pump made my TD5 seem quiter, I was told it contained more rape oil than in the UK. ?
Post #401299 22nd Feb 2015 11:21pm
Caterham
I put some Esso supreme in the other day and didn't notice any difference other than the 20p per litre extra cost (so that's approx. so that's an extra £10 !!! (I suspect I got ripped off but they're all more expensive).
I'm not suggesting Redex or 2so is as good as some of the others but they're certainly a damn site cheaper than doing the Esso supreme.
as mentioned above and by myself for me the biggest improvement is from the 2so - runs much quieter / smoother.
(similar results as when I add my home brew bio - in terms of sound).
Thumbs Up
Post #401302 22nd Feb 2015 11:26pm
munch90
Ive tried lots of proper additives over the years , forte, wynns,redex,millers etc and found 2so the best
Post #401305 22nd Feb 2015 11:39pm
bear100
A few mixed reviews Confused
So we can all agree it doesn't do any damage to the engine but additives of some description do make an audible difference and not just a placebo?
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #401355 23rd Feb 2015 10:10am
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
I've tried it too and despite wanting to feel or hear some difference I can't honestly say I did....
Post #401667 24th Feb 2015 1:55pm
Fatboy Slim
Wales
Hmm as a diesel engineer I would strongly suggest not putting it in anything with a DPF. As a diesel engineer that has experienced a few multi-authority stops in rural areas including diesel dipping I certainly wouldn't use any two stroke oil that's red in colour Laughing
Post #401734 24th Feb 2015 5:31pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
I've never used 2 stroke oil in mine, it gets Tescos finest usually with about 8p a litre off due to their Fuelsave offer.
I have no idea if 2 stroke improves the Cetane rating of the fuel or if it improves the power.
I usually add a shot of Millers commercial vehicle fuel additive to each tank of fuel, in cold weather it does seem to start easier and with less diesel knock with additive in the tank. I can't say I have noticed any difference in the performance though.
It is supposed to add some degree of lubricity to the fuel, which might be of benefit if the additives package from the pump isn't up to much.
I haven't had any trouble with the 2.4 up until now, however the EGR has been getting noisier for the last 12 months, then moving onto a definate strained sound on a cold shut down, this is now starting to happen even after a run so I dare say the EGR is toast. Whether this would have happened on BP ultimate at 21K mikes I have no idea. However I have seen a few other posts over the years suggesting EGRS seem to die at about 21K.
Didn't the Transit get a modified water cooled EGR ?
Maybe time to get a remap and get it blanked off.
Jonno
Post #401752 24th Feb 2015 7:10pm
mick
Thought these are water cooled as well
Post #401754 24th Feb 2015 7:19pm
ericvv
^^ I believe that the Puma 2.2 (incl. Defender) have a watercooled EGR. Not sure if you hear the chuka chuka chuka cleaning cycle with those anymore. Do you???
From new I always used the cheaper accross the border French supermarket fuels. My Puma 2.4 EGR packed up after the first 5000 km, was replaced under warranty, then no more problems and had a specific a bit raunchy cleaning cycle noise for the next year or so.
Until I switched away from those cheap French supermarket fuels, and started to use BP Ultimate exclusively. Within two tanks of that, the cleaning cycle after shutdown became suddenly much more gentle, and remains so until the present 73.000 km. Needless to say, BP Ultimate is here to stay, for the last 4 years never used anything else anymore. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #401757 24th Feb 2015 7:28pm
Page 2 of 3 <123>
