Home > Technical > Key remote issues
SGH
Key remote issues
I bought a while back one of these keys with integral fob but it does not seem to work as it should. Once vehicle is unlocked and started if I switch ignition off I need to re-lock the vehicle then unlock for it to be able to start. Rolling Eyes
Anyone else had this issue ?
I was planning on getting from Brendan one of the flip key and fob and don't want to experience same issues if it's a issue with just my vehicle.
Simon 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #401171 22nd Feb 2015 4:55pm
munch90
sounds like the transponder chip is faulty or not there at all
when you unlock by the button that switches off imobiliser and unlocks doors
if you turn off without locking and open door get in , then the chip turns the imobiliser off
say sounds like chip is not working or poss its not there on that type of key
if you still got a standard fob and key I take it that works ok ?
Post #401173 22nd Feb 2015 5:00pm
Have you just tried pressing unlock quickly instead even though it's already unlocked?
Post #401183 22nd Feb 2015 5:35pm
munch90
yes it should be that you can push just unlock without locking first
Post #401196 22nd Feb 2015 6:04pm
rallysteve
Could be the transponder pick up coil around the ignition barrel (presuming it has one to start with)
Post #401197 22nd Feb 2015 6:06pm
munch90
yep could be the ring , sure a 2012 will have one
really did to test with standard fob , if it all works ring must be working
Post #401198 22nd Feb 2015 6:09pm
dgardel
Italy
Re: Key remote issues
Simon
you need to reset the AS10 Alarm ECU....
IMHO isn't the fob.
Have you a Nanocom evo? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #401206 22nd Feb 2015 6:25pm
SGH
I will take a look tomorrow tipping it down here now.
Yes it has the coil but that has been moved slightly due to fitting XENG lock shroud but key never worked correctly before coil was moved.
No issue with standard key and fob that works just fine. 993 Varioram - Guards Red
Post #401210 22nd Feb 2015 6:32pm
Is it doing it all the time or is the immobiliser arming itself first. (Red flash on dash)
Post #401212 22nd Feb 2015 6:41pm
SGH
Steve with the all in one key it only works once to start the car second time it's immobilised so have to lock unlock and then start. 993 Varioram - Guards Red
Post #401213 22nd Feb 2015 6:42pm
munch90
99.9% sure its the chip in the key
has it always done it right from the start with the one piece key?
Post #401217 22nd Feb 2015 7:00pm
SGH
Yes done it from day 1 993 Varioram - Guards Red
Post #401219 22nd Feb 2015 7:16pm
munch90
sounds like its the wrong key internals for the later alarm units
maybe for the older units as fitted to rover 200's etc , they done same thing , you had to push buttom after imob cut in
Post #401223 22nd Feb 2015 7:32pm
SGH
I got this from group buy on here quite a while back from dgardel I seem to recall. Mine is a 2.2 I guess I must have been only one to have an issue. 993 Varioram - Guards Red
Post #401234 22nd Feb 2015 7:50pm
Lorryman100
Simon, try a fob re-synch of the 10AS and see if that helps. On the key fob press unlock then lock 4 times within range of the 10AS.
Post #401250 22nd Feb 2015 8:28pm
