Home > Wheels & Tyres > 255/85R16 on Sawtooth
Page 2 of 3 <123>
Jim_Bean
How do you guys find the KM2s on tarmac? Are they a little skittish in the wet?
I hear great things about them but I would want to be sure about putting them on our 110 - our family bus!
Do you feel confident with them on wet tarmac, fully loaded?
Post #400898 21st Feb 2015 6:48pm
Never had a moment's concern, wet or dry, laden or unladen.
Post #400963 21st Feb 2015 9:06pm
Jim_Bean
Do you think they are as good as the All Terrains?
Post #400980 21st Feb 2015 9:41pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Does anyone run them on stock suspension? m
Post #401037 22nd Feb 2015 6:23am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Yes, mine are on stock suspension.
No problem on tarmac (wet or dry) either.
Simon
Post #401039 22nd Feb 2015 7:51am
Yep on stock springs
Post #401048 22nd Feb 2015 8:31am
100inch
ken, I have seen the 2 pics of your truck but do you have another one? Showing the height from a different angle pls? Thanks m
Post #401053 22nd Feb 2015 8:54am
ericvv
This spring the new BFG A/T tire will be launched in our 235-85/16 size. First evolution in 12 years. Full name is BFG All-Terrain T/A KO2.
Unless you are a regular serious off roader, might be worth the wait. They are already available in USA in different sizes, and sofar reading only very good reviews on them.
Now that I am forced to buy new summer wheels/tires, I intend to buy these when they become available here in Switzerland, understand that is going to be April like rest of Europe, so good timing.
Intend to put them on new OEM gloss black HD Wolf wheels. Think will be good looks on the SVX, and will be more than enough aggressiveness for me who does 99.9% on road driving.
Eric
http://www.bfgoodrichtires.com/tire-select...re-details
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #401056 22nd Feb 2015 9:16am
Every bit as good.
I can't think of a single reason which would make me consider even for a moment fitting ATs instead of KM2s.
Post #401057 22nd Feb 2015 9:29am
ericvv
Post #401058 22nd Feb 2015 9:31am
100inch
Nice tyre but what about a similar OD to the 255/85? m
Post #401059 22nd Feb 2015 9:40am
I'll see what I can dig out
Post #401071 22nd Feb 2015 10:04am
ericvv
What is the logic of putting 255/85-16 on a Puma by the way? Don't believe a Defender is homologated for that size in the first place, and it surely throws the accuracy of the speedo well off. If going wider, doesn't the 265/75-16 makes more sense?
Post #401074 22nd Feb 2015 10:11am
100inch
cheers ken
Post #401079 22nd Feb 2015 10:24am
couplands
Eric
The 255/85 size gives the extra bit of clearance under the diffs which is useful. They are also a bit narrower than the 265/75 size and hence cut through the mud a bit better.
As the speedos on modern cars read a little high, I find the 255/85 size bring the reading back to what it should be. I just have to remember there is no leeway on that reading and stick strickly to the speed limit.
It's a good point about homolgation and I must add it to the list of non-standard items on my insurance.
KM2 are no noisier than the ATs, I find them very quite. They pass the new EU laws for tyre noise (76dba..?).
Simon
Post #401086 22nd Feb 2015 11:08am
Page 2 of 3 <123>
