Home > Maintenance & Modifications > PORTAL AXLES, BOLT-ON PORTALS,Etc.- Options available?
Page 1 of 3 123>
smb
Hi All,
This is for anyone who has a good knowledge of or has fitted Portal Axles to a 110/130.
There are some good write ups(Oilworker on Devon4x4 forum & rallywerke), but there doesn't seem to be any/many companies advertising/marketing them.
Who are the best companies to look to for the expertise, modifications and purchase of the units? What range of lifts are there. Im not after anything too extreme, but around 4-6 inches would be good.
Thank you in advance Thumbs Up
Steve
Post #400582 20th Feb 2015 2:26pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
There aren't that many companies providing portal axles as there generally isn't that much demand.
Before companies started making custom portals, people used axles from Unimogs I believe.
Tibus have received a fair mount of criticism for blatant copying products other companies have spend years and thousands developing. The twin motor winch was what wound (excuse the pun) everyone up. Think it was a gigglepin copy.
From what Oilworker has said on Devon 4x4 the portal axles are pretty reliable although he seems to do regular oil changes on them..
Not cheap, questionable morals from the company that builds them, but pretty good kit.
Hope this helps!
Post #400600 20th Feb 2015 4:08pm
smb
Thanks Mike, Thumbs Up
I had heard something similar hence questioning whether there are any other makes out there. Granted, I may have to go onto mainland Europe to get them.
Post #400606 20th Feb 2015 4:32pm
Mike_B
There's a company in USA that do similar stuff.. Killer axles maybe?
Not specifically defender stuff but they could help I guess..
Post #400608 20th Feb 2015 4:37pm
Mike_B
Post #400612 20th Feb 2015 4:42pm
You need leg extensions first!!!!! QRZ M8VPF
Post #400621 20th Feb 2015 5:14pm
Laurie
May I ask why?
It'll make the ride very unstable and the steering will be very 'lumpy'.
Post #400629 20th Feb 2015 5:40pm
Why do you say that? There's no reason why it should do either of these, and certainly the guy with the 130 mentioned above hasn't reported any such issues.
Post #400635 20th Feb 2015 5:58pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
There was a firm based near Inverness called Portalrover, I do not know if they still exist though.
They also did 6x6 conversions
Chris
Post #400646 20th Feb 2015 6:22pm
Laurie
Have you ever driven one? I have.
'tis true it was over 30 years ago but it felt horrible even at 30 mph. I've driven a Scammel Explorer that felt a lot more stable depite the driving seat being several feet higher.
Post #400656 20th Feb 2015 7:13pm
I think they've got better since then! Thumbs Up
Post #400662 20th Feb 2015 7:30pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Something to bear in mind with portals....
when I worked at the main stealer we used to get a few 110s in with portal axles, the whole conversion was called Agrover.
Anyway, they were 200 and 300tdi engines at that time, one day one came in with a misfire, one cylinder not working at all.
It took a while to sus it out but when I removed the cylinder head no 4 piston wasnt as far up its bore as no 1 piston when at top dead centre. The crankshaft was twisted causing no compression on number 4 cylinder.
The cause.....portal axles are geared down by quite a bit so add that to the gearbox gearing and the transfer box and the diffs then the wheels are geared down a lot from the speed of the engine. So the engine is running clockwise at say 1200rpm, driver leaves gearbox in first gear with the clutch down and rolls backwards. the input shaft from the gearbox going into the clutch is now spinning the opposite way to the engine and all that gearing down is now working the opposite way round and the wheels are spinning said shaft very very fast. The driver lets the clutch pedal up and yeeeehaaa one twisted crankshaft.
Very expensive Big Cry 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #400726 20th Feb 2015 11:01pm
T1G UP
Tibus
http://www.killeraxles.com/bolt_on_portale_e.html
they do the full height Kit like robert has on his 130 or a lower version
last time i asked they were eu 10,000 plus taxes
Post #400727 20th Feb 2015 11:07pm
roel
I know some people use Volvo axles. They are lighter then the Unimog axles I believe.
https://www.youtube.com/watch?v=Piw1IrRAWdQ Roel
2003 90 Td5 (2009-now)
Post #400784 21st Feb 2015 9:57am
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
http://www.aulro.com/afvb/members-rides/85...0-a-7.html
Worth reading before handing out your hard earned $.... m
Post #400799 21st Feb 2015 11:41am
Page 1 of 3 123>
