![]() | Home > Td5 > Lazy throttle pedal |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
It was modified to keep it out of harms way, so cable ran to the 'pot'. This is just normally at the side of the pedal. QRZ 2e0vpf
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
Early ones were two track later ones were three track. Mines a later three track. Shout if you want to try it. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
Thanks LA. Will do, how ever I think mine is a 2 track? 1999 Defender TD5 110
Finally got around to removing the cubby box and found the hi/low plug. Bridged the contacts and throttle pedal still lazy. Next is some contact cleaner on the throttle pedal and see what gives. 1999 Defender TD5 110
