Home > Puma (Tdci) > 90 bulkhead removal bar and factory cargo barrier
peterl
1987 Defender 90 300 Tdi HT Epsom Green
with the xs station wagons and as an option on h/t's the bulkhead can be / is removed which allows seats to be moved further back. Landrover do a cargo barrier as well, my question is, is this in 2 pieces and has anyone got any pictures of the said item fitted and if it does come in two halfs, can you just fit the lower half, again any pictures would be helpful.
thanks.
Post #400436 19th Feb 2015 10:32pm
NickMc
You used to be able to get the td5 one in two pieces for the later CSWs with no bulkhead.
Post #400468 20th Feb 2015 12:58am
Taken from here:
http://www.lrparts.net/full-length-dog-gua...2007.html#
Fitting instructions are here:
http://topix.landrover.jlrext.com/topix/co...oupId=1667
Looks like you can fit the lower section on it's own but will leave some tabs/brackets sticking up.
Post #400535 20th Feb 2015 12:06pm
peterl
That's the one, thanks.
Will now see if I can find a second hand one or find a fabricator to make something similar up for the bottom half only.
Pete
Post #400547 20th Feb 2015 1:15pm
Mdm
They are made by travall for lr I beilve
Post #400670 20th Feb 2015 8:09pm
