![]() | Home > Technical > Second water pump in 6 months :-( |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Hi Guzzio, may be just bad luck...
But I had the same experience, after approx. one year after replacing again a waterpump failure. My local independent (but LR specalised) garage replaced the pump without costs. So, off to your garagist... 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| Guzzio Member Since: 09 Feb 2014 Location: Belgium Posts: 29 |
Hmmm ... thanks for the answer VeeTee. I hope it's just another bad pump again. I have faith in my local garagist, so back to the workshop ... or i do it myself. Can't be that hard!?
But i wonder ... could it be that the little drive shaft (don't know how do you call it in proper English) that makes the water pump turning, is just a little bit 'outlined' so it makes the water pump fail time after time? Just thinking loud ... |
Ah, i now see you are talking about the TD5, these use a different design waterpump (the well known P-gasket failure is a 300Tdi thing). Then could be a O-ring leaking?
Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
