Home > Td5 > Drive Belt Replacement
Ken B
Hi All,
A quick bit of help please! my auxiliary drive belt tensioner bust its bearings and the belt suffered a bit of damage so i have replace the tensioner and ordered a new belt.
The new tensioner arrived and fitted no problems, Unfortunately the belt is not the same story Sad I ordered via eurocarparts for a quick delivery but the item supplied is a good inch or two shorter than what came off !!!
The item they specified via online search is PN: 7PK1715 or a Dayco 202 77 1175 Drive Belt
I have a 2002 TD5 with AC ( Rolling with laughter never been used) so need to know what belt to get as there is no way the belt i got supplied is even close to fitting.
Help appreciated, Cheers..
K.. Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #399769 17th Feb 2015 8:31pm
munch90
Is there any numbers on the old belt
if so using new belt numbers as example it is 7pk so 7 grooves wide , 1715mm long
or order one bit shorter/longer so just knock off or add on what you think you need
normally one a few mill either way will still fit
Post #399779 17th Feb 2015 8:46pm
Ken B
Thanks munch! unfortunately there is no markings remaining on the old belt but that may be because they were eaten when the tensioner failed and it minced it all up Laughing
I will measure what remains of the old belt and see if I can get an idea on real length. Defender 90 TD5 County -
Post #399795 17th Feb 2015 9:01pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Buy a genuine belt, the're not expensive.
I've seen some pretty poor pattern part belts - not worth it.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #399813 17th Feb 2015 9:26pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
You could consider a genuine one from the dealer (approx. £27) all you need to do is give them your reg / make / model.
Probably need two of you to fit it and easier if the viscous fan is off Wink
Post #399814 17th Feb 2015 9:30pm
Martin
Site Admin
You need a 7PK1800: http://www.advancedfactors.co.uk/7pk1800-a...6393-p.asp  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #399818 17th Feb 2015 9:41pm
Ken B
Thanks Martin et all... I will do a few measurements now on what is left of the old belt and see what I can get hold of tomorrow. Defender 90 TD5 County -
Post #399833 17th Feb 2015 10:09pm
jst
Sounds like you just have a non addition belt supplied. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #399924 18th Feb 2015 8:04am
Ken B
Right thanks all the correct size is indeed 7PK1801 with thanks to my local friendly garage for a quick supply... fits like a glove and easy enough to do solo when using a flexi head ratchet to push back on the tensioner!
I ordered an extra through advanced factors to add to the toolbox.. cheers martin! Defender 90 TD5 County -
Post #400069 18th Feb 2015 7:00pm
Martin
Site Admin
Great stuff Very Happy  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #400077 18th Feb 2015 7:24pm
Waldo
I know this is a very old post, but I'd rather revive than go new.
Could someone confirm for me that this:
https://www.advancedfactors.co.uk/pqs10150...1221-p.asp
Is the correct auxiliary drive belt I'll need for my 2003 Td5 XS with aircon? Defender 90 XS TD5 (03 Reg)
Post #917291 16th Aug 2021 6:17pm
landy andy
Yes. Thats correct ðŸ‘ðŸ»
Post #917336 16th Aug 2021 10:43pm
Waldo
Ta Andy,
I thought it might be you that would confirm it Thumbs Up Defender 90 XS TD5 (03 Reg)
Post #917413 17th Aug 2021 2:05pm
