Home > Technical > snorkel
landy
snorkel
do i need to fit a snorkel to my td5 before i have a remap? Confused
Post #39981 6th Sep 2010 8:05pm
K9F
Simple answer no! Raised Air Intake or Snorkel may aid/increase airflow under certain conditions but will not 'be taken into account' by usual mapping, so it makes little or no difference to the end result! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #39983 6th Sep 2010 8:10pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
More cosmetic....unless your going through big puddles Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #39989 6th Sep 2010 9:09pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
a friend of me had lose hp with snorkel.
i have heard that td5 and snorkel don't love each other www.newfoundland.gr
Post #39991 6th Sep 2010 9:19pm
landy
cheers guys just one more thing Whistle which snorkel will fit without having to move my aerial Thumbs Up
Post #39994 6th Sep 2010 9:37pm
K9F
Landy,
With the Safari Snorkel you do not need to move the aerial aparently! See here:
http://www.landyzone.co.uk/lz/f7/snorkel-f...49071.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #40009 6th Sep 2010 10:13pm
mse
no aerial issues with the safari
Apparently Safari are the only manufacturer that monitor airflow as part of their snorkel design Mike
Post #40014 6th Sep 2010 10:51pm
landy andy
Mantec snork does not need ariel to be moved and was designed with Land Rover to be fitted to the Td5.
Andy
Post #40024 7th Sep 2010 7:59am
landy
thank everyone going to buy a safari i think Thumbs Up
Post #40097 7th Sep 2010 7:23pm
K9F
I bought a Safari - no regrets! Thumbs Up If you're unsure here may be a good start to have a look for comparisons....
http://www.defender2.net/forum/topic2105.html
At the risk of antagonising Discocuzzy I'm going to post a picture....No wheel/tyre combo so I should be ok... Rolling with laughter
Does give a good comparison view I think...
The elephant trunk is mine and the trilby hat Fekete's. Hope this helps. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #40104 7th Sep 2010 7:36pm
landy
cheers for the pic Thumbs Up i like both of them Confused i even like the oem land rover one which i can get for £90 now i am confused Big Cry
Post #40143 8th Sep 2010 8:08am
