![]() | Home > Technical > Dash Clock |
Is the dash clock meant to be back-lit on a 2011 Puma or is that way too 'Avant garde'? Same question for the Hazard switch.
Neither of mine light up and I was wondering if they were meant to and have the same (now blown/broken) fuse or electrical feed? I know I pretended to have X-Ray and Night Vision whilst in the Army, but this is taking the p**s. Thanks in advance for any help. ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
They should light up when the lights are on.
Andy |
Hazard switch light bulb can burn out. Bulbs are available from rimmerbros. You can read it all in below thread where PaulMc enlightened me.
![]() Eric http://www.defender2.net/forum/topic12482....light+bulb You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
That's a LR part, not specific to Rimmer Bros - STC1205
But in answer to the original question, yes both the clock and the hazard switch should backlight. The triangle is backlit red on the switch. ![]() ![]() |
Brilliant, thank you all. Seems a surprisingly common fault. And thank you Eric for the previous thread, now I know how to get to the switch to check.
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
Undo the four torx screws holding it in and without the holder you will see where the bulb holder is
Rallyevo3 Member Since: 30 Jan 2020 Location: Worksop Posts: 8 ![]() ![]() ![]() |
Many thanks
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
There is an LED for this now you can fit off eBay to fit in.
I have one, but annoyingly I replaced with a regular one before it was avilable. So for now I keep it on the shelf until such a time I may take the dash out. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 786 ![]() |
When I replaced the bulb in my clock I cut the corner off the holder so next time I need to change the bulb it will be easier😊
Is it the green led one for a fiver?
Yes, on eBay. Cann’t comment on how good it is but I have one to try one day. ____\We|Will|Win/___
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 842 ![]() ![]() ![]() |
I brought the led one, when I tried to fit it it would not stay in like the origional one and did not make good contact so I reverted back Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
