Home > Maintenance & Modifications > Terafirma shocks
mick
Terafirma shocks
Have lived up to there usual name of poor quality Rolling Eyes heard a pop this morning on way to my 1 st job didn't think much about it until there was a steady pool of oil appearing Sad
Took it off at home the bottom weld has blown so ordered some Koni ones from larkspeed Thumbs Up
Post #396455 6th Feb 2015 5:57pm
AberrDef
Surely covered by warranty to have broken so soon after purchasing? Surprised
Post #399265 16th Feb 2015 12:27pm
NickMc
Yeah should be covered by warranty, not trying to tell you to suck eggs, but did you fit them correctly? As i know they had a bulletin out as people where fitting them incorrectly and the break exactly where you've described.
Post #399781 17th Feb 2015 8:48pm
NickMc
Terrafirma shock fitting lesson;
The first 2 pictures show a correctly fitted rear shock absorber. The second 2 pictures show the results from incorrectly fitted shock absorbers.
Even the strongest shocks will break if not fitted correctly, we do expect them to be used off road and we accept they have to withstand abuse and although no shock will last forever they will last much longer and often exceed expectations if fitted correctly...........
The top shock mount has 2 washers that are flat on one one side and dished (convex) on the other, to the uninitiated they look better with the rounded or dished side facing out especially after you have spent 10 minutes hunting around in the grass for them! In fact the dished side is intended to fit against the shock bush to allow the shock to move during wheel travel, fitting the flat side against the bush will pinch the shock restricting movement and causing it to break?
On the bottom mount you can clearly see the different bush mountings in the pictures. Post 1994 Defenders and Discovery 1s have cups welded to the axle shock mount to locate the bushes, for anything other than standard travel shocks these must be removed. In the picture where the new bush is visible the cups have been removed allowing freedom for the shock to move during wheel travel Pinching the shock washers or any metal to metal contact will prevent the shock from moving and cause failure such as in the 2 pictures, either the pin breaks off or the bottom can break out of the shock itself.
https://m.facebook.com/Terrafirma4x4/posts/10152322875954603
Post #399783 17th Feb 2015 8:51pm
mick
Fitted correctly standard set up no off roading
Post #399863 17th Feb 2015 10:57pm
Ken B
Old man emu setup for me, on second set of shocks now but if that happens every 10 years then it is great value as I offroad them quite hard! Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #399865 17th Feb 2015 11:01pm
mick
Just so I know what I am on about when I fire these shocks back 1 is defo fecked as the oil has come out Rolling Eyes but the other doesn't push back out if you compress it in where the new Konis do and the old standard do as well Very Happy so can I say that's fecked as well
Post #402094 25th Feb 2015 7:18pm
landy andy
I also notice from the above photos that they have still not sorted the issue that the top mounting ring on the damper is larger than the retaining washers. This problem causes the damper to be pushed off the bush and into the chassis (if lucky) or smash your fuel filter off.
Old man emu off me too, now.
Post #402234 25th Feb 2015 10:51pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Now on my second set of TF rear shocks in 4 years and approx 30,000 miles.
With the first pair (+5" Pin-Pin type) of shocks I found that the lower pins bent on full articulation and the bushes perished badly after 2 years. TF do not sell just the bushes and they are different sizes to standard LR versions.
When they were replaced with the second set, the damping rate was noticeably different between new and old.
Wish I had gone for OME first time round now...
Post #402484 26th Feb 2015 7:44pm
