![]() | Home > Maintenance & Modifications > Puma 110 - front end lift |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
How much lift do you need?
Currently I use home made space blocks below my springs to get enough height for my 35" simexes. How my suspensions set up will be when my 90 is finished I don't know yet. This is however working very good for me and I drive this way already a few years. For the front axle you can still use your standard shocks and springs. Click image to enlarge The only thing you have to look at is the lower part off the pin off the shock and the hole in the standard axle support. If you don't have enough lift the pin might bend on full articulation as it might still stick in the original support. So or you have to make the hole bigger or you have to shorten the pin. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Derrick at LRS will be able to supply you with the correct OME springs, just tell him what you want to do and he'll be able to send the right springs. QRZ M8VPF
| smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233
+1
Derrick knows his stuff and is a top bloke. |
| rover Member Since: 26 May 2012 Location: Yorkshire Posts: 150
Land rover heavy duty 110 and 130 front springs will lift it by about 1.5 inch. basically the same as 90s rear springs.
| v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 455
I thought about the option of putting the HD springs on, which is a cheap way to do it, but I have these in my 110 and lift the front up quite alot even with the winch and winch bumper on the front so I wonder whether it will lift it up too much with just the standard bumper on the front.
I need to put in on the level tomorrow and see what the height actually is. I saw these and wondered if they might do the trick........ http://www.gwynlewis4x4.co.uk/product/1-in...g-spacers/ |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052
They are very good, I ran them for a few years, ideal if you are happy with everything just need a lift.
Andy |
