![]() | Home > Maintenance & Modifications > Split Charge Upgrade |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255 ![]() ![]() ![]() |
I put the rear bolt in first - slotted the top bar so that it would slide under the nut.
Used existing negative cable but cut off the end and re-terminated, connected to aux at rear, then second cable to connect to main batt. My main is at the front, aux at the rear - seems logical but doesn't matter! My Disco 'best bits' Defender 110 XS CSW 2013 |
Mark
You have choices .. The negative lead can either be: extended and routed to the aux/rear battery, it could be terminated on a common rail or refabricated to fit. It does not matter front or rear for main/aux, when I did mine, I retained the oem positive terminal and mega fuse I'm not sure if the 2.2 layout is different to the 2.4 If we're doing it again, I would put the aux fuse box in the other seat box together with the other fuses |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
I slotted the clamp bar for the rear bolt
Rerouted and retained the original Neg lead and exit point from box , as well as used the org positive with the factory megafuse Battery it the same position as other here Main to front of seat box, Aux at the rear,, Power to fuse box under driver's (RH) seat with the others California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2712 ![]() ![]() |
Many thanks for the advice. Will get on with it later.
Tim, did you get my text with my wiring diagram? I think its right but wanted to be sure ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
@Tim,
Many thanks for the call. Things are a lot clearer in my head now. Should be done and dusted later. Then onto a few other projects 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
![]() No problem California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Wel another long day at it. Both batts fitted and the relay works perfectly. Aux fuse board fitted in the other side. Just need to run the cables to it and start the fun job of retiring all the toys I have already fitted to the temp fuse board.
Another long day to go and then it'll be done. ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
