![]() | Home > Maintenance & Modifications > TDCI/TD5 fuel tank on V8 chassis |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Leave side tank and put LPG tanks between chassis rails at rear instead
Fozzauk Member Since: 05 Feb 2014 Location: Derbyshire Posts: 271 ![]() ![]() ![]() |
I'm not keen on running the engine on lpg. Plus I would still need to move fuel filler as the puma tub is at the back whereas the v8 is behind the drivers door.
My thinking is to put the puma tank in and hook that upto the fuel filler, then link the two tanks and only use the rear fuel filler if that's possible? Failing that I will make a panel for the inside of the arch to hold the old filler pipe. I'm not keen on chopping into the tub and having two fillers visible. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
It's much easier to do on a 110 than a 90. I think the easy way to do it would be to fit a td5 1/4 chassis complete with all the fixings and brackets, not forgetting the tow bars different as well . I think Les Brock has done it.
