Home > Td5 > Sump Plug Thread is bugg... - sorry slightly broken!
BlondeBimbo
As you may have guessed from the title the thread in the sump is stripped!
Had a slight drip on the drive (in addition to me - this one was oil) - when I got under, it is clear the thread is stripped as the plug just turns!
New plug the same!
There are kits around to tap the M16 x 1.5 to M17 x 1.5 - to which you fit M17 sump plugs - this appears the way to go to me, I have no problem with the plugs - I could get them made to fit the Landy's counter-bored sump - but.
Is there sufficient material in the sump to tap out to M17?
Any ideas?
Julie - AKA BB
Post #39845 5th Sep 2010 12:27pm
K9F
Helicoil it! That would be an alternative solution without removing too much material. You'd still have to tap it out though so going to M17 may be the best solution or fit a replacement sump pan - dependant on cost of course!
http://www.screwfasteners.co.uk/helicoils-intervis.html
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #39851 5th Sep 2010 1:01pm
Martin
Site Admin
As an alternative, I have a Td5 sump for sale:
http://www.defender2.net/forum/topic3700.html
£40 ono Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #39856 5th Sep 2010 1:41pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
I had the same thing after trying to do a service on a monster hang over (Not reccomended)
In the end after weighing up the cost of buying the tap, or a helicoil kit of the correct size I just replaced the sump.
If you go that route, remember to torque the bolts up to the correct torque and to use a little thread seal as they tend to rattle loose. 2002 Defender 110 DC
Post #39863 5th Sep 2010 3:10pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
this happend to me a few cars ago......had a tap set so tapped out and put a bigger bolt and a rubber seal washer as well. BM52
Post #39880 5th Sep 2010 5:42pm
roel
I use always plenty of sealant an both sides off the copper ring and a little on the thread and just thighten it a little more as hand tight. The sealant will keep it in place.
Please note: That it works for me on my Land Rovers is not a guaranty that it will work for you on your vehicles. So don't sue me if it didn't work. Whistle Roel
2003 90 Td5 (2009-now)
Post #39908 5th Sep 2010 11:17pm
landy andy
Never been keen on ally sumps and regular oil changes. So I brought the Difflock sump plug. No longer do I have to be careful and I put the hose straight into an old oil container and watch it fill, when full stop and chage container. Nice and clean.
Top bit of kit, wish I had brought one years ago.
http://shop.difflock.com/defender-drainplug-p-40.html
Andy
Post #39970 6th Sep 2010 6:50pm
