Home > Maintenance & Modifications > Rear winch
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Rear winch
I saw a neat rear winch today on a defender on the motorway. It was a traffic jam so I spoke to the owner....he said it was fitted by cutting back the rear cross member. Does anyone know of a known technique for this and any other options. I really liked the look of it as it was flush with the rear "bumper" flat metal bit across the back (whatever it's called!!) any brackets on the market?
Post #398607 13th Feb 2015 10:59pm
My old truck, was it like this??
Post #398610 13th Feb 2015 11:08pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
I can make you one like mine, It bolts on to the rear x member and has a 2" receiver built in.
I am on a different computer so I will post pics in the morning. Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #398611 13th Feb 2015 11:11pm
TJ101
Easier way is to fit via a Devon 4x4 rear winch cross member
http://www.devon4x4.com/index.php?page=sho...;Itemid=14 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #398612 13th Feb 2015 11:12pm
leeds
Ours
A rear winch in many ways is better then a front winch Thumbs Up
Brendan
Post #398620 13th Feb 2015 11:42pm
Jonno1968
Yes, exactly like that.
Post #398662 14th Feb 2015 9:02am
It was built by Devon, it was literally a letter box cut into the x-m, they since developed what Tim posted up, though it's easy enough to do Thumbs Up
Post #398670 14th Feb 2015 10:03am
Anderzander
The rear petrol tank from td5 onwards limits how flush you can get it though - and I'm not sure about having one stick out as far as it would need to ...
Post #398692 14th Feb 2015 11:28am
ibexman
North offroad used to do a nice weld on mount but stopped production for some reason
Post #398694 14th Feb 2015 11:37am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I have a problem with the letter box style.
When Land Rover designed the rear cross member with all the holes in it it had to have a type approval. Now if you had a rusted hole that size it would be a M.O.T. failure so how do get a pass with the same size hole deliberately cut into it? Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #398709 14th Feb 2015 1:15pm
If you are going to all that effort could you make one like the Ibex that could run out to the front or the back?
Or you can just rig your front winch for a rearwards pull an save all the effort?
Post #398739 14th Feb 2015 3:22pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
There's always the 2" receiver option which you can put on the front and the back.
This way you only need 1 winch for either end, and keep it in doors when not used, which keeps it clean.
Of course you won't have the "look" but if that's your main objective you wouldn't probably be interested in the back winch anyway.
Not to mention the extra cost in case of an accident...
Post #398788 14th Feb 2015 7:09pm
jst
rear tank as mentioned is biggest issue.
rear winches also tend to get a lock more crud in them than front (usually lower down) and how many times do you end up stuck part way up something with the rear sat in the mud a while. plus vac at rear driving doesnt help maintain it.
cl2 option is a good practical way around it but depends on how often you are going to need it and if you envisage needing to operate two winches at once. (ie front and rear) Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #398842 14th Feb 2015 9:24pm
NickH
Heres mine, done , fitted and tested winching a tractor and muck spreader out !
 2003 Td5 90
2013 sport hse
Post #399613 17th Feb 2015 1:07pm
Grenadier
Thanks Zone30, that's good to know. As it happens I prefer the look of the Bowler bumper and was wondering how a winch might fit (if at all) but that it might ruin the look of an expensive item. Maybe this would be the way to go....? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #399623 17th Feb 2015 1:52pm
