Home > Maintenance & Modifications > Genesyz Battery Management System
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
I'm looking for a dual battery management system and Iìve found 4 models:
- Genesyz Battery Management System (by Devon)
- IBS dual battery system
- National Luna DIY split charge system
- T-Max digital monitor split charge.
Price are very different, starting from £83 of T-Max up to £235 of IBS and Nationa Luna.
T-Max seem a cheaper copy of National Luna, but I don't know if the quality is good as well and because it's very tricky I don't want to risk to remain without both batteries because of his fault... Shocked
So I'm looking for Genesyz system, that seem the most complete and, what not least, has a small main controler!
The only things that not convinces me is the maximum switch currents:
- Main isolating switch: 80 Amps @ 12 Volts
- Auxiliary equipment switch: 30 Amps @ 12 Volts
I state I am not an electronics genius, so I could easily say Censored Whistle , but the auxiliary one I think is not enough, because with compressor, refrigerator, lights, CB radio, water pump, inverters and others the consumption is much higher!
Anyone is using this system?? Matteo
Defender 110 Td4 SE MY 09
Post #39875 5th Sep 2010 5:22pm
leeds
Commercial post removed
Post #39878 5th Sep 2010 5:40pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
I have a frend who has had a few of those systems fitted to his expedition truck.
He started out with the National luna, but binned that after the relay melted on a trip to Morocco. He now has a Genesyz system fitted and that has been fine for his many trips accross the work.
For my part, I have the IBS unit and have found it a very easy system to get on with. 2002 Defender 110 DC
Post #39889 5th Sep 2010 6:52pm
TACK
Did my own recently with the BEP VSR 125amp, not been in 50c or -20c yet but it worked for my needs, devon 4x4 do them http://www.devon4x4.com/products_a/p375c36...-125a.html £60 Thumbs Up
Discocuzzy also used the 300amp, do a search and you will find it on here Thumbs Up
Post #39903 5th Sep 2010 9:26pm
Bomber82
leeds wrote:
£235 for IBS???
Suggest you look here
You have a pm
Brendan
Leeds, apart from prices, what do you think about the swith current of both system? Matteo
Post #39913 6th Sep 2010 6:07am
Naks
I have a Genesyz system in my Puma. Installed it when I got the truck in Feb 2010, performed faultlessly on our June trip to the Kgalagadi.
Not sure if it's my unit only, but once or twice I have noticed the unit reboots itself when the car is off, i.e., it seems like it thinks the car is being switched on. But it has not failed, so I can only assume it is operating as intended.
Post #39915 6th Sep 2010 6:22am
roel
Why not use an X-eng relay? Do you really need the electronics to see how much power is left?
If you want to make it more perfect I would install a time delay relais and put that at 10 minutes or so. This way you main battery will have the charge lost while starting back before the other battery will be connected.
The electronics don't give you a better charge in your batteries, at least I have nowhere found an explanation how the systems will do that. Roel
2003 90 Td5 (2009-now)
Post #39921 6th Sep 2010 8:05am
Bomber82
X-charge is only a 180 A relay.
What I need is a split charging, with also the possibility to disconnect batteries.
The possibility to check level of charge is required because of a lot electronical components I've installed that can cause possible discharge to very low level...
I know that with one ralay, a switch and power level gauge I can do the same, but first of all I don't want to make some strange connections and second I don't think I will spend less money...one ralay + switch are around 80-90 pounds + 30-40 per gauge + wiring and spare accessories. Matteo
Post #39926 6th Sep 2010 9:24am
discocuzzy
This is a 300amp voltage sensing relay i use, really simple to use (you can also switch the unit so both batteries cab run in paralel using either the red dial or a switch on the dash)
Neet install with substantial cable Thumbs Up
Looks like it has been replaced by this unit:
http://www.devon4x4.com/products_a/p36061c...00amp.html
This is my install:
I use a national luna monitor to keep an eye on everything Thumbs Up You cannot teach stupid people to do clever things
Post #39929 6th Sep 2010 10:02am
leeds
The relay supplied with the IBS system is 200 amp continuous rated or 500 amps for short period of time.
The relay with the Genesis system is a can type relay and IIRC is rated at 180+amps.
Both systems will allow starting from second battery/winch operations. Whilst a winch can demand up to 500 amps it would rarely be used at maximum power for long periods of time.
Have used both systems and have noticed that the Genesis system can seem to cycle the start up sequence as another poster has pointed out, especially when second battery has got low on charge. My solution was to swop batteries over so secondary low battery becomes the main battery. Charged main battery becomes second battery and start the engine using link facility and then it charges the now low main battery as per normal. Hope that description makes sense.
So far the IBS system has worked fine for us.
Many different ways of achieving split charging from a simple manual switch system up to a fully automatic one. Just ensure that you get a system which will cope with your current needs and any foreseeable changes in your needs in the near future which will fit your budget.
HTH
Brendan
Post #39933 6th Sep 2010 10:38am
discocuzzy
Sound advise Brendan Thumbs Up You cannot teach stupid people to do clever things
Post #39935 6th Sep 2010 10:49am
Bomber82
Honestly I do not trust much of the electronic systems, in case of failure would remain without batteries.
But it is also true that it would be easy enough to restore the original form on the main battery to allow me to at least start the vehicle.
Simple manual switch may be forgetted from me or someone else who use the car (sometime my brother or my girlfriend use my 110...) and this is more dangerous for the battery life.
So I prefer to trust in elettronic! Cool Matteo
Post #40399 13th Sep 2010 1:16pm
Bomber82
At the end I choose!!
Friday has arrived the IBS! Thumbs Up
Next week I'll start the installation, main original battery + Optima Yellw Top Matteo
Post #44531 7th Nov 2010 10:40am
BigMike
Have you bought the yellow top yet?
Post #44548 7th Nov 2010 3:35pm
Bomber82
Yes, now I have everything, also cables and connectors. Matteo
Post #44566 7th Nov 2010 6:58pm
