![]() | Home > Puma (Tdci) > Exhaust smell in cabin? |
manifold gasket , turbo gasket , egr valve ?
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
Centre box?
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Super - thanks
Just check down in the passenger footwell on the vertical slope to see if the rubber bung hasn't come out. It can give you a whiff of exhaust gas at start up if the exhaust manifold/downpipe to turbo gaskets are old and leak a little on start up untill they get warm.
Turns out that the back door had shifted slightly, the upper left-hand corner wasn't even touching the seal anymore.
Time for a Mantec wheel carrier I think... |
