Home > Td5 > Alarm query
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
Alarm query
Can someone please tell me where the sensor is situated on a 110TD5 when you lock and unlock the car with the key fob button. I seem to have a delay in the signal sometimes, despite having a new battery in the fob.
Post #398340 13th Feb 2015 12:54am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
I believe it's behind the instrument panel.
Post #398351 13th Feb 2015 4:02am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Mine has always had this issue (over 10years..!)
I've not been able to fix it, intermittently the car won't activate the door locks, but the alarm arms/disarms and the indicator lights flash. I have to manually activate the locks with the key.
Looking forward to hearing any fixes.
Simon
Post #398360 13th Feb 2015 8:21am
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
On a 90, assuming it's the same on 110 the alarm remote receiver is up behind the drivers side speaker. Just drop it out and you will see 2 plastic boxes screwed to panel just higher than the speaker hole.
The aerial for the receiver is an orange wire that just hangs out, it's about 20cm long with about 5mm of insulation stripped off.
Post #398465 13th Feb 2015 3:14pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Extending the wire can improve the range.
Post #398719 14th Feb 2015 1:47pm
