- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
ozzie1989
| 2010 110 Axle/Tbox/Gbox oils again - sorry! | |
Hi all, I've read so many posts and had recommendations from Opie, Castrol etc. that I'm now stuck in a loop and confused.
Can anyone see an issue with running CASTROL SYNTRAX UNIVERSAL PLUS 75W-90 (meets both GL4 and GL5 spec) in the Axles, Transfer Box and Gearbox?
Or do you think I'd be better with the following which Opie recommended:
Axles: CASTROL AXLE EPX 80W-90 GEAR OIL
Tbox: CASTROL AXLE EPX 80W-90 GEAR OIL
Gbox: CASTROL SYNTRANS MULTIVEHICLE 75W-90 FULLY SYNTHETIC MTF
Engine oil I'm OK with thankfully!
Many thanks and sorry for dragging this up yet again! Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
10th Feb 2015 2:51pm |
ozzie1989
Great stuff, thanks Now: 2010 2.4 TDCi 110 Utility Wagon
12th Feb 2015 1:09pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
