![]() | Home > Maintenance & Modifications > Lower the Tow Ball height on a Defender 90 |
| tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279
I don't need to measure to know the standard Land Rover tow bar on my 130 is very close to 50 cm off the ground. I'm guessing no one working at LR must ever have noticed that.
The one from Nakatanenga seems exactly what I'm after. |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Click image to enlarge What's the difference between these two setups? Both have the tow ball in line with the chassis stays and the mounting bolts for the tow bracket below the stays; albeit on the rear step bumper it is lower. |
Unladen - I don't know what the real world consequences of adding weight would be, only the theoretical one based on the spring specs: [URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] Where are the measurements taken from to make these 90mm or 160mm lower - is it the lowest bolt hole on the backing plate?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
i had a guy a few months ago towing an overloaded mini digger and trailer on one of the tdi disco brackets bodged on right angled plate on the bottom of the crossmember with no stays just two bolts
| Griff_L322 Member Since: 26 Mar 2015 Location: North Wales Posts: 89
I'm after the plate in the blue defender where is it from?? i want to drop the ball using a plate but want a 6 hole version so it's attached with 4 bolts not 2 |
| All times are GMT |
