Home > Puma (Tdci) > Increase fuel consumption
Davefarmer
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
How do folk how are we all??
I have a 07 2.4 90 defender with fuel consumption issues
When first had it it retuned 30mpg no problems at all towing town work what ever pretty constant
Very quickly last 3/4 tank fills it's reduced to 20mpg
Had few error codes had a fit where by revving it hard would put it into limp mode and half power
Garage cleared these for me said it the codes related to the turbo and injectors but weren't sure which injector
Power now good where it lacked before they cleared the error codes but now it's only doing 23mpg
Been back to my specialist garage they have looked it over and can't find any reason
Iv cleaned out the maf sensor this was pretty chocked
Cleaned map sensor
Had new air flow mass sensor on the air box
EGR valve seams to work just fine
Can't find any boost leaks though will check more thoroughly nothing is obvious
No dragging brakes
Injectors are tight
No obvious fuel leaks and drips, stand it on clean concrete over night only thing on the floor is my coffee as I struggle through the door!!
Not got anything over silly fitted to it only mantech snorkel and steering guard other wise standard
It's done 102,000 miles up to date with servicing but is due oil n filter change in about 2000miles
Any ideas?
Think I will change the oil n filters early and just see doesn't use drop of oil between services.
Post #397687 10th Feb 2015 7:24pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
turbo could be dragging you've done a lot of what it could be id throw some injector cleaner in the tank first you can get a turbo cleaner too that goes in the tank too hope this helps good luck
Post #397702 10th Feb 2015 7:50pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
VCV
Had the same issues and similar on our other 2 2008 110's
Once past the 100000 mark it seems the valve starts to play up
I was barely able to keep it below 15l/100km in the end
Will post more in short time in new topic
New valve, pump relearn and pilot correction and everything back to normal
2cents Thumbs Up
Post #397703 10th Feb 2015 7:59pm
andydef90
just a thought I know you said you had checked the hoses to the turbo but have noticed black smoke from your exhaust even a small hole will upset the fuel mixture
Post #397705 10th Feb 2015 8:03pm
Davefarmer
Thanks guys very helpful information Thumbs Up
Post #398042 11th Feb 2015 11:51pm
dulwich man
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Try Archoil AR6600 turbo cleaner
Post #398291 12th Feb 2015 10:15pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
tatra805 wrote:
VCV
2cents Thumbs Up
Hello tatra805.
Any update on this?
Thanks.
Post #414781 8th Apr 2015 1:26pm
tatra805
Hi Fatman,
Now with +2000 km on the counter including a fully loaded 4day weekend trip i can confirm that the vcv solved:
on mine
- rough idle on startup at around 0° temps
- brought back consumption to 9l/100km on mixed roads max speed 100km/h (90% non highway) with roof rack, rtt, and gear loaded (mind i have a BAS remap so +1.5 for non mapped according my stats)
The white 110 had almost no load and a good driver (an economic one with over a million miles on his counter) and returned similar mpg, whereas the engine would cut out at cold start it now purred as a puma should with it's new vcv
The 130 is a 2.2 and only added a couple of mm's of oil content during the trip... 11000 km on the counter and approaching 2nd oil change due to diesel DPF oil contamination Big Cry Banging Head Thud Thud Thud
Post #415151 10th Apr 2015 12:02am
