Home > Wheels & Tyres > Wheel carrier and bumperette combi |
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 |
That would be a great combination I reckon, especially if they made 90-specific bumperettes to allow for the mudflaps. |
31st Jan 2015 9:48am |
JMG if you do a search on Google Images for 'Defender Rear Ladder' there are several short ladders depicted fixed to the nearside rear quarter that would not impinge on the swing away or bumperette at all.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
31st Jan 2015 9:51am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Hardcharger, if you need any help with Safari Equip give me a shout as we supply their gear and are very close to the factory.
JMG, with a 90 you have a large choice of wheel carriers. The Patriot roof rack ladder bolts above most rear bumperettes onto the two rear cross member to body tub bolts. So ladder is not an issue.. HTH Brendan |
31st Jan 2015 10:23pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila, SFO, Amsterdam Posts: 688 |
Thanks leeds!
Will definitely ring you up when the time comes. Do you ship overseas? |
9th Feb 2015 3:29pm |
Hi HC we have sent wheel carriers to Australia, Zambia, Philippines etc.
If it goes outside the EU then we deduct UK VAT of 20% from the goods. Web shop does not do carriage automatically for foreign destinations, so will need delivery address to work out carriage costs. Brendan |
9th Feb 2015 8:35pm |
Thanks leeds! Will work out what I need and get the coin.
10th Feb 2015 12:09pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Here's my modded Safari Equip bumpeerette:
Click image to enlarge Click image to enlarge The inner support has been shortened by 5mm, so that it meets the Naka Stainless Wheel Carrier (which has a 5mm plate at this point. The inner part of the inner bracket has been removed. It still looks mighty strong. £30 IIRC at my local blacksmiths... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
23rd Feb 2015 4:57pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
Is it not possible to add a 5mm spacer piece (to match)to the outer side attachment ...I know it would make the off side bumper 5mm further out than the nearside but it would save you some dosh and most people would not notice!
4th Mar 2015 11:17pm |
I did think of that, but you would still need to cut-off the innerside of the innermost bracket (with my combi anyways)... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
6th Mar 2015 9:44am |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
Would the Safari Bumperettes fit when the vehicle has LandRover chequer plate on the rear corners?
Pickles. |
6th Mar 2015 10:38pm |
Yes!
6th Mar 2015 10:56pm |
