|  | Home > Technical > No headlamp flash |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387    | Get a power probe and work along the loom from the bulkhead, failing that, I'd take the front wheel arch spats off, disconnect the earths and pull the whole harness out, strip it all back and re do it.
 I'm just doing a v8-90 and the front loom is terrible, I'm going to remake the whole front end, from the bulkhead forwards on both sides. QRZ M8VPF | ||
|  9th Feb 2015 9:26pm |
| Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618    | I have already remade the front loom, and as the high beam works fine, I know that the common parts of the wiring are good......according to the wiring diagram I have, ALL the wiring is common though.... so that's that theory out the window.... This is why I don't understand the problem - though it appears I am not alone. V8 90...WIP | ||
|  9th Feb 2015 9:33pm |
| Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618    | Solved it now.... poor stalk contact, was OK on the test bench, but fitted - it no worky. V8 90...WIP | ||
|  9th Feb 2015 9:48pm |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387    |  QRZ M8VPF | ||
|  10th Feb 2015 7:39am |
| Posting Rules
