Home > Technical > Spot lamp wire querie?
Page 2 of 2 <12
K9F
If you're half as frustrated as me (with the way this thread is going not sexually) I sympathise and understand fully. Bow down
If I can offer any more advice (or wit Laughing apologies for that) just holler. If you had been nearer I would have been on my way to assist long ago.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #397343 9th Feb 2015 5:01pm
munch90
sounds almost like its back feeding somewhere
in the pic that blue connecting to the dash wiring , (looks a bit thick to me ) are you sure that's the right wire from the aux light wiring loom ?
Post #397346 9th Feb 2015 5:09pm
Rudski
Munch
There are 3 wires that end of the loom 2 have spades on which plug into the back of the switch, the other is about 10 inch longer that goes up to the back of the instrument cluster, looking at the instructions that's the only wire to connect to the main beam feed.
If I look at them again I think my eyes will start to bleed Big Cry
Is it to early to start on the drink Evil or Very Mad
Post #397356 9th Feb 2015 5:39pm
Rudski
Thumbs Up
Thanks again, when I get some wire to complete the job, and it still doesn't work I will be straight back on here Bow down
Post #397357 9th Feb 2015 5:41pm
PaulMc
Rudski wrote:
... as you can see no room for anymore switches
To address this problem on MY15 Defenders, the very latest driving lights kit (VPLDV0103) contains a single switch bezel, which is cut into either the RH or LH facia side panels, using the supplied template -
The full instructions are here - http://topix.landrover.jlrext.com/topix/service/document/489853
It would be useful if this bezel was available as a separate part.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #397464 9th Feb 2015 9:58pm
Excellent instructions there Paul, but geez do you see where I mentions to cut the dash with a Stanley knife. Shocked
I would say that is bloomin dangerous considering the thick tough nature of the dash plastic.
I'd do it many other ways other than that to the same effect and safer too.
I know it's workshop manual / literature there but I'd do that a different way myself.
Post #397466 9th Feb 2015 10:02pm
munch90
Rudski wrote:
Munch
take there is a main positive feed as well back to battery etc
if you can list the wiring and where its connected and to what
Post #397467 9th Feb 2015 10:05pm
Rudski
Thanks paul
I don't have the bazel, think I might just tuck the switch away under the dash.
Munch Yes main feed runs through a fuse then back into relay, this section of loom was already made up. All I needed to do was run everything to where it needed to be, with leaving the switch out and connecting the two loose ends seems to be causing the problem, when I get more wire I'll get back onto it and let you know the results.
There's one positive to get out of this, I'm certainly learning all about my defender, I would never have attempted this on my range rover sport Thumbs Up
Post #397476 9th Feb 2015 10:24pm
Pickles
Having a 2013 Defender & having the "Factory" driving light kit fitted, I too was wondering where the switch would go, because on the '13, there is a spare "spot" for the switch, whereas on later models there is not.
Well, at least the current factory kit makes allowance for this with an alternate switch fitting location & "bezel" to retain a factory finish.
Pickles.
Post #397513 9th Feb 2015 11:31pm
munch90
Think i would prefer a switch hidden away then havea hole cut in the side of the dash with a switch stuck in it in the middle of nowhere
Post #397516 9th Feb 2015 11:39pm
Rudski
Well it's been a while, but due to hip surgery I haven't been able to get back to this job, today after running some extension wires in so I could have the switch hidden under the dash I wired the switch in and hey presto it all works so after all the issues with trying not to have the switch it must be as part of the genuine landrover loom the switch needs to be connected.
So I just need it to get dark so I can adjust the spots to suit. Thumbs Up
Post #408430 17th Mar 2015 5:01pm
hip surgery - that's not your day job is it? Shocked
Post #408547 17th Mar 2015 10:21pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
^^ Rolling with laughter
Post #408578 17th Mar 2015 11:45pm
Rudski
Rolling with laughter supacat
Post #408584 18th Mar 2015 12:12am
PaulMc
Bezel for 2 x Switches
I've just found this -
http://www.nuggetstuff.com/defender2switchbezel.html
The seller is based in Australia, they don't say if they ship worldwide.
It's priced at A$27.50 - which works-out at just over £13 at current exchange rates.
Post #475774 24th Nov 2015 1:23pm
Page 2 of 2 <12
