Home > Maintenance & Modifications > Boomslang loom ...
ti-fat-man
United Kingdom 2011 Defender 110 Puma 2.4 USW Alpine White
Boomslang loom ...
I was curious about this item from a few threads on the forum. A couple of Stella's later, hit the purchase button ...
I've read the thread about splitting the fuse box to enable it to pass through the grommet on the seatbox. However I cant seem to learn the knack. Any tips.
What is the best run for the blue feed cable to the seatbox, and should I slip some plastic conduit over it?
Any other tips
Cheers Alan
Post #397090 8th Feb 2015 8:49pm
munch90
I personally would put some conduit along it ,
normally need a very very small screwdriver down the side of the terminal in the fuse boxe to release a small metal/plastic tag that clips the terminal in to the plastic housing
Post #397091 8th Feb 2015 8:55pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I done exactly like you said, run it in some conduit and along the top of the chassis, bit of a faff but well worth it Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #397093 8th Feb 2015 8:56pm
PrivateB
exactly as ian series 1 said Smile
Post #397111 8th Feb 2015 9:59pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
What's it for? Excuse my ignorance! Td5 background!
Post #397132 8th Feb 2015 11:25pm
munch90
Headlight upgrade loom
to give full voltage to headlights ( and improve brightness ) and protect the weak headlight switch
Post #397137 9th Feb 2015 12:02am
Mike_B
Ah, cheers munch. Makes sense now.
Post #397203 9th Feb 2015 11:04am
ericvv
I guess this boomslang loom is very similar to the Landreiziger loom also well discussed here. In which case there is no need at all to take the live feed from the battery. You can just take it from the alternator which has also a permanent live. That is what my dealer did, much easier. It is well commented in a "Landreiziger" thread on here. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #397693 10th Feb 2015 7:33pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Re: Boomslang loom ...
Any other tips
Hi Alan, I've posted how I did my own setup here: http://www.defender2.net/forum/post395594.html#395594
Long story short, I purchased 2 meters of 10mm convoluted sleeve to protect the wire.
The benefit of connecting the live feed to the battery is to keep the fuse inside the car and not in the engine bay.
Cheers,
O.
Post #397819 11th Feb 2015 9:07am
ti-fat-man
Cheers o4dn,
great 'walk through' with the installation tips ... Thumbs Up
Post #397988 11th Feb 2015 9:35pm
Cupboard
to split the fuse holder, take the fuse out, look under the holder where the wires go in and you should see a little slot on one side. Wiggle a screwdriver in there whilst gently putting the wire out and it will release the locking tab that keeps the female spade in the holder. I didn't bother protecting my cable. That may come back to bite me but I just ran it along the chassis and tucked it in to all the cable ties where my winch cabling goes.
Post #398078 12th Feb 2015 10:13am
jst
i bought this same kit for £7 inc postage from China! looks exactly the same including the relays and one is a 5 pin too as per the other thread on here. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #398215 12th Feb 2015 7:24pm
1964_cooper
Any chance of a link to the Chinese loom jst ..?
Post #398896 14th Feb 2015 11:30pm
ti-fat-man
I had a couple of hours spare this afternoon, so though I make a start on this mod.
Like others I thought I'd share my thoughts/tips ...
Post #399095 15th Feb 2015 8:18pm
ti-fat-man
I made a little bracket with clip, and mounted this to a bolt fixing for the washer bottle. Mine was on the nearside wing.
Ran the loom section for the offside down and through a hole in the radiator bay. Used a section of 20mm electrical plastic conduit to protect the loom through the hole.
Passed the loom for the offside headlight and passed it through a similar hole. As o4dn had factored, was if you pull the yellow cover back the connector will just pass through. Then gently sqeeze the cover through and reinstate.
Question. How have others routed the main feed cable from the headlight postion to the seatbox?
Cheers Alan
Post #399099 15th Feb 2015 8:26pm
