![]() | Home > Site News & Feedback > Why no security section or stickies? |
Do a search under 'layers' there's plenty of invaluable information in the threads that come up!
![]() Treat every day as if it is your last....one day you will be right!! |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6039 ![]() ![]() ![]() |
A section on security might not be a bad idea as sometimes threads getting mixed in with other ones and you miss them. A search is good, but a section for security might better then you can search just the security section? 1999 Defender TD5 110
It was one of my last but in retrospect should have been one of the first.....
Invest in a decent tracker will good security support. ![]() Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21019 ![]() ![]() |
Then there is a great info section for thieves to check out possible items to overcome.
Public site this is so it could happen. |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
There is also the Landywatch forum that you can look at, not very busy as it deals with the security side only but still worth visiting. ONE LIFE, GET IT!
dba11 Member Since: 12 Feb 2014 Location: St Jory de Chalais Posts: 26 ![]() ![]() ![]() |
Apologies for posting in the wrong section
![]() None of my comments were a criticism, just an observation or maybe a suggestion. I have used the search facility and found loads of ideas on the security front, which I will be looking into once I find the right Defender. Cheers Daren |
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1098 ![]() ![]() |
You raised a reasonable question Daren, don't worry. It's one area Defender owners are very sensitive about and OpSec is all important. Basically, First rule of Defender Security? Don't talk openly about Defender security.
![]() Visual deterrent, physical barrier, tracker. That's it really. How you do it is up to you. ![]() |
