Home > In Car Electronics > Dab Shark Fin Aerial
AndrewS
I have fitted one of these http://www.dabonwheels.co.uk/SharkFin_DAB_FM_Car_Aerial.html
I fitted it towards the front of the roof in a similar place to this but a bit further back. The reason for fitting it towards the front of the roof is the fact that the vehicle has a roof rack fitted so this was the only place it would physically fit.
Thanks for the pic Buccaneer Thumbs Up
I drilled through the roof and also drilled a hole in the bottom of the rib big enough to allow a socket to pass through the hole to tighten the aerial fixing nut.
The sides of the rib are still in place so as far as I am concerned there is little impact on the strength of the rib.
The reception is very good in fact I get better DAB reception in the 130 than my Disco 4 130's have feeling's as well you know Smile
Post #396229 5th Feb 2015 10:03pm
Dab's the future, purely for Radio 6!
I'm gonna get one soon. QRZ 2e0vpf
Post #396233 5th Feb 2015 10:13pm
Does it work under the roof rack then?
I fitted a 1/4 wave DAB aerial on a mag mount on a steel plate on the roofrack which worked pretty well until the rubbish Pioneer head unit decided that it had an aerial fault a few days out of warranty! Apparently this is a common fault with Pioneer DAB units and is actually caused by a non-replaceable internal fuse failing and is not really an aerial fault at all, and the unit must be sent back to Pioneer for repair at my expense.
Result - no DAB, and I'll never buy another Pioneer unit!
I did find that coverage is very poor in Dorset so in practice it is no great loss.
Post #396290 5th Feb 2015 11:47pm
AndrewS
Yes its under the rack Shocked and its got great signal, not been to Dorset in the 130 yet so cant comment on reception there. I live on the Welsh border and there are 'black' spots with reception, well there is in the Disco 4. So far I have not encountered any signal loss. 130's have feeling's as well you know Smile
Post #396329 6th Feb 2015 9:03am
There are areas in Dorset where a wireless set with valves is still considered a bit too new-fangled, and where the latest 4WD tractor is an ox! Shocked
Post #396340 6th Feb 2015 10:20am
theorangebandit
Love my DAB I have an adaptor that allows the original antenna to be used for dab and fm. But my head unit has stopped receiving dab ! Its definitely a software fault I've tried a spare antenna the window one and still no signal 😞
Post #396341 6th Feb 2015 10:21am
blackwolf wrote:
.... the rubbish Pioneer head unit decided that it had an aerial fault a few days out of warranty! Apparently this is a common fault with Pioneer DAB units and is actually caused by a non-replaceable internal fuse failing and is not really an aerial fault at all, and the unit must be sent back to Pioneer for repair at my expense.
The really annoying thing with the Pioneer unit is that with this fault it still receives DAB fine but when set to DAB the display says something helpful like "ANTENNA FAULT" and the controls are locked, so you don't know what it's tuned to and you can't retune it anyway. But is still receives a signal so clearly there's actually no antenna fault.
I think it is concerned with the circuitry used to power a powered antenna, but clearly it is moronic design. Big Cry
Post #396345 6th Feb 2015 10:33am
AndrewS
I have powered my antenna from the vehicle not the radio Thumbs Up 130's have feeling's as well you know Smile
Post #396358 6th Feb 2015 11:01am
Mine is passive, not powered, which makes me even happier about the internal fuse that's blown!
Post #396366 6th Feb 2015 11:18am
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
Andrew S, really like the look of that. I have a wing mounted dab aerial from dab on wheels and the reception is rubbish. it isn't just the signal either because I have had courtesy cars with dab and they have been flawless.
how easy is this to fit? does the headlining come out easily and more importantly, doe it go back without it looking like it has been tampered with?
I have a jvc single din head unit with a jvc dab box.
I was originally put off the shark fin because it didn't get a good review.
Post #396536 6th Feb 2015 10:27pm
AndrewS
Yes lining out, its easy enough to remove the lining dependent on how 'stuck' the fasteners are.. A lot easier if you have a trim removal tool. Get a few spare lining fasteners before you start the job.
Even with a trim removal tool the fasteners are sometimes difficult to remove without damaging the head lining, I use a pair of these to get behind the head of the fastener to pull it out.
Or just snip the head off the fasteners that want to stay put. Once the lining is out you can easily remove the remainder of the 'stuck' fasteners. 130's have feeling's as well you know Smile
Post #396618 7th Feb 2015 10:00am
AndrewS
Went into Deepest mid Wales yesterday no DAB signal Neutral 130's have feeling's as well you know Smile
Post #396895 8th Feb 2015 10:09am
Plenty of Sheep thou Rolling with laughter
Post #396897 8th Feb 2015 10:13am
K9F
I live in Dorset what's DAB all about then?....... Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #396898 8th Feb 2015 10:16am
AndrewS
Post #396920 8th Feb 2015 10:46am
