![]() | Home > Maintenance & Modifications > Interior Storage For 110 Hardtop |
schweps Member Since: 21 Oct 2014 Location: Zonguldak Posts: 47 ![]() ![]() ![]() |
According to me, hinged doors are headaches especially at limited areas that every cm3 matters.
So shutters will be used instead. And special U shaped rails to guide them. Later on, drawings plotted on cupboards are used to see whether side panels of the closet will fit or not. Mistakes noticed as usual and been corrected. After few trials, measurements are fixed and sent to an autocad file. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Meanwhile 1.000x2.000x2,5mm 3 plates have been purchased from a supplier. Plates are not chosen as checkered by purpose. Two of the plate has been transfered to a workshop equipped with laser cutting and press brake machines. The result of laser cutting was wonderful. From the other plate, shelves and other necessary parts were cut and bent. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
![]() Click image to enlarge ![]() Click image to enlarge To fix side panels to the body, rails and shelves to the side panels, pop up rivets are used. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge With 3 shelves for each side closet, sufficient storage volume is gained. At one side, two of the shelves are not fixed by purpose. They can slide upwards and long equipments like camping chairs and tables could fit there. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
I’m not sure if the inside dimensions of 5 door SW 110 or 3 door 90 are same with 110 hardtop but i can share the autocad file with anybody who asks for.
So feel free to contact. senolesiyok@gmail.com ![]() Click image to enlarge ![]() Click image to enlarge |
Good job, very clever idea with the roller shutters. Not quite ready to prep the back of my 110SW but when I do I am sure the CAD will come in very useful, so thank you for the offer.
Good luck with the rest of the work.. ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Thanks Grenadier.
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
That's a neat solution scweps!! Nice to see a different solution for storage in the rear of a defender
![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 ![]() |
Really appreciate the quality of the workmanship gone into this BUT, a friend of mine had a very similar setup and those roller type doors rattled so badly they nearly drove him insane... Maybe yours are a different type?
Thanks jomara and need4speed for your input.
Actually it has been few weeks that i've been using it and no rattling noise noticed. The guiding channels have special grooves for wick kind of material. So there is no metal to metal touch occurs, at least for now ![]() |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Fantastic, I love it when people have brilliant idea's that working with land rover's.
Would it be possible to have a copy of your plans. stevensearle67@aol.com |
Hi Steven,
I've sent the model and drawing files. Regarding the rattling questions;I hope the attached photos showing the details on the shutter pieces and the wick material inside the groove of the rail would help you to figure out the precautions that have been taken. ![]() Click image to enlarge ![]() Click image to enlarge |
That's great, you've done something that looks far better than the stuff I'm even planning for mine!
Thank you Cupboard,
If you like I can send you the model and dwg files aswell. Cheers. |
Hi Schweps. That is a super job mate. I absolutely agree that doors inside a confined space like the back of a Defender are an absolute PITA.
Like a few other folks on here I am also working on a storage solution to fit my needs, and those of our dog whilst travelling. The darned things take up so much space, i cant help thinking we should have gone with a pet gerbil or something that could live in the cubby box... ![]() |
Hi Geobloke,
I've been away for some period and sorry for not replying until now. Thanks for your kind message and wish you luck on the way finding your own solution. Cheers. |
