Home > Td5 > Is there a permanent live and earth in the towing socket |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
This is the seven pin. |
1st Feb 2015 8:55pm |
And 13 Pin |
1st Feb 2015 8:57pm |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
So no then as I have the 7 pin, ok thank you for that 2005 TD5 90 CSW XS
1st Feb 2015 9:02pm |
The 7 pin towing socket is the 12N socket. No permanent live. But you can add a 12S socket, which does have a permanent live. If you do a search on here for 12S, you will find plenty of info about that.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
1st Feb 2015 9:28pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19705 |
What would the purpose be for asking?
1st Feb 2015 9:33pm |
Does it have 8 pins then? 2005 TD5 90 CSW XS |
1st Feb 2015 10:11pm |
No Keith its a different configuration. I will find one for you
1st Feb 2015 10:13pm |
There you go mate. This one is for a caravan. in the old days you would have 2 plugs when towing. One for the trailer lights etc and one for the caravan electrics. |
1st Feb 2015 10:17pm |
I'm going to fit a waterproof steel lockable yellow box on to my drive, attach a chain as a land anchor to the back of the defender also with an added security alarm that takes its supply from the towing socket with battery back up that will activate when it's unplugged or the wire is cut. 2005 TD5 90 CSW XS |
1st Feb 2015 10:25pm |
Oh right I keep the 12n and add a 12s 2005 TD5 90 CSW XS |
1st Feb 2015 10:28pm |
Keith
you could also add a charging circuit from a Ctek charger so you can keep your battery in tiptop condition. |
1st Feb 2015 10:31pm |
What about a DIN plug and socket and if the worst comes to the worst it will pull out with no damage if you forget and go to drive away, it will still sound your alarm but is less prone to ripping plugs and sockets apart.
http://www.ebay.co.uk/itm/2-Pin-DIN-Hi-Fi-...1395432695 |
1st Feb 2015 10:32pm |
Can see the point if he's using the yellow box as a ground anchor. he will be going no where
1st Feb 2015 10:34pm |
Then I would have to get 240v supply out there too, would be nice to have at a future date though. 2005 TD5 90 CSW XS |
1st Feb 2015 10:42pm |
