![]() | Home > Pictures & Video > Lest We Forget |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327
A bit of photoshop for a fitting end.
Click image to enlarge Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
| sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
Steve |
| TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179
Ashes to ashes, dust to dust, if you don't take it out and use it, it's going to rust...... 2013 Aintree Green 110 Station Wagon SX
| Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
Sadly those vehicles that do stand around doing not a lot and with low mileages, often seen to deteriorate and become unreliable. Bearings, seals and engine components that are designed to reach working temperatures and move - oils and coolants designed to be pumped around a system. Chassis that benefits from airflow and not sitting in a bath of condensation - there are few mechanical vehicles or devices that benefit from being static museum pieces. Sometimes a low mileage vehicle isn't actually that good an investment.
Dust to dust, ashes to ashes .... |
| BIGJOCK90 Member Since: 26 Jan 2015 Location: Wallacestone Posts: 7
| Smilesapart Member Since: 28 Sep 2013 Location: Suffolk Posts: 735
I second that. All cars seem to work better, run smoother and have less problems if they are used regularly
| Housey_d444 Member Since: 27 Apr 2013 Location: Kidderminster Posts: 32
| Blondie Member Since: 31 May 2014 Location: London Posts: 46
Drive it daily .....
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Why have the greatest driving machine on earth if you spend the whole time polishing it?
Defender, Built to work! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
