Home > Technical > Trailer socket connections
Eduardo
Hi there !!
I'm starting the repairs of my "new" folding camper and I want to check the wiring diagram for the lights.
This is the scheme that I do (trailer socket - trailer lights scheme) but I dont know if it is correct or not, so comments are welcome...
Some questions:
1.- What is the difference between pins 5 and 7, both appears as 12V directly from the battery passing through the Lighting control. That means that I need to have my lights on to have 12V supply in the camper from the car?
2.- As far as can see there is not a pin for the reverse lights ¿why? In our case fog lights are not required but reverse ligths should be necessary.
Thanks in advance for the help Eduardo
Post #39441 31st Aug 2010 7:48pm
Glynparry25
Re: Trailer socket connections
Not to sure about the 12v, but personaly for the power supply into the trailer I wouldn't use a 12n plug- would rather use something meatier with anderson connectors,
As for the second point...... other than some new trailers just bought into service witht he army, I have't seen trailers with revese lights.
Hope this helps a little,
Glyn Sheep
Post #39452 31st Aug 2010 9:26pm
BlondeBimbo
there are three types of plugs/sockets for trailers
12N
Is the normal one for towing
pin Use
1 Nearside indicator
2 Rear Fog
3 Earth
4 Offside indicator
5 offside tail light
6 Stop
7 Nearside tail light and number plate
There is no reversing light
12S
Is the normal one for power supply to a caravan (supplements the use of 12N)
pin Use
1 Reversing light
2 Caravan Battery
3 Earth
4 12v power
5 not used
6 refrigerator
7 not used
It is normal to have two sockets/plugs for caravanning 12N (black) and 12S (Grey)
However there is now a new 13pin single socket as follows:
in Use
2 Rear Fog
3 Earth for pins 1-8
4 Offside indicator
6 Stop
8 Reversing light
9 Caravan Battery or interior lights (perm supply)
10 refrigerator (Ignition controlled supply)
11 Earth for pin 10
12 sensing device
13 Earth for pin 9
Does that help?
BB
Post #39461 31st Aug 2010 9:51pm
Eduardo
Thanks for both answer,
Apears that I need to install the 12S Confused
Thanks Eduardo
Post #39463 31st Aug 2010 9:59pm
