|  | Home > Technical > Central locking problem ... |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | More than likely a broken wire in the convoluted tubing between the door post and the door. A real favourite to break due to the flexing when the door is opened and closed. | ||
|  31st Jan 2015 11:36am |
| ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517      | cheers for that. its not quite as snowy here (bedford) as your signature but still a tad nippy. could i test for good continity of the cables at the plug end? | ||
|  31st Jan 2015 11:48am |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | If you're going for a continuity test try to find the joiner that usually is just poked in the door pillar behind where the rubber convoluted tube fits in. You might be able to spot a break visually by pulling the outer tube loose and pulling backwards and forwards. | ||
|  31st Jan 2015 11:54am |
| ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517      | yes i know that block, hangs around in the cut-out on the pillar. cheers | ||
|  31st Jan 2015 12:08pm |
| ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517      | JWL ... spot on the money     Does anyone know the part number and ££ of this loom section? btw ... what is the function of the plastic sheet inside the door near the lock assembly? Cheers Alan   Click image to enlarge | ||
|  31st Jan 2015 5:17pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | LAND ROVER	3618,95.
 на заказ от 20 до 30 дней 0 1 YMM000251 1 HARNESS FRONT DOOR, DRIVER, LESS ELECTRIC WINDOWS, WITH CENTRAL LOCKING (V)2A622424 LAND ROVER 988,62. На заказ от 7 до 10 дней 0 1 YMM000271 1 HARNESS FRONT DOOR, DRIVER, ELECTRIC WINDOWS, LESS CENTRAL DOOR LOCKING (V)2A622424 LAND ROVER 2890,23. на заказ от 20 до 30 дней 0 1 YMM000291 1 HARNESS FRONT DOOR, DRIVER, ELECTRIC WINDOWS, WITH CENTRAL LOCKING (V)2A622424 LAND ROVER 2160,60. на заказ от 20 до 30 дней 0 1 YMM000261 1 HARNESS FRONT DOOR, PASSENGER, LESS ELECTRIC WINDOWS, WITH CENTRAL LOCKING (V)2A622424 LAND ROVER 2197,40. На заказ от 7 до 10 дней 0 1 YMM000281 1 HARNESS FRONT DOOR, PASSENGER, ELECTRIC WINDOWS, LESS CENTRAL DOOR LOCKING (V)2A622424 LAND ROVER 3793,50. на заказ от 20 до 30 дней 0 1 YMM000321 1 HARNESS FRONT DOOR, PASSENGER, ELECTRIC WINDOWS, WITH CENTRAL LOCKING (V)2A622424 | ||
|  31st Jan 2015 5:25pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Splice outside the gaitor with some better quality cable running through it.
 Same problem same time.... http://www.defender2.net/forum/topic34611.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  31st Jan 2015 5:28pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | Id go K9F much easy to repair it Splice in new wiring
 USE LR016312 No Longer Available | ||
|  31st Jan 2015 5:51pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Rustyboxx had a similar issue with his electric window, same place (in the gaitor) same issue (cable broken) with some good quality hermetically sealed splices took about 40 minutes to an hour to sort.
 Good luck.  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  31st Jan 2015 7:10pm |
| ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517      | at £30 for a new one i'm thinking of patching this one up. what are hermatically sealed spices and where to buy?
 all i have currently (pardon the pun) are a packet of red/yellow/blue crimps and a simple crimper from Halfrauds ... | ||
|  31st Jan 2015 7:46pm |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | Pop into a Maplins if you've got one local. | ||
|  31st Jan 2015 8:15pm |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018      | |||
|  31st Jan 2015 9:07pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | I use these MIL standard aerospace grade. They come in three different sizes and have a heatshrink sleeve preformed with resin at each end. When the sleeve is shrunk over the splice the resin melts forming a totally waterproof repair. Blue is the middle size, red smaller and yellow being the largest. Pay for the postage I'll lend you the tool and throw the splices in for free. I must have the tool returned. Alternatively use one of your type and try to keep it out of where it will flex or get damp.
 http://uk.rs-online.com/web/p/crimp-butt-s...s/4445665/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  31st Jan 2015 9:12pm |
| LinDens90XS Member Since: 24 Feb 2012 Location: Merseyside Posts: 83    | Had the same problem. Just cut and spliced  approx 6" cable, then checked offside door and caught one cable with about 3 strands left and the other just cracking, so repaired that as well. rear door seem fine though. Regards
 Dennis. | ||
|  3rd Feb 2015 12:06am |
| Posting Rules
 . Does anyone know the part number.
