![]() | Home > For Sale & Wanted > Hannibal roof rack Defender 90 |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
Have you got any pictures of it ? 130's have feeling's as well you know
| CarlS Member Since: 10 Apr 2007 Location: Probably near you Posts: 148
Nope, could take some though
Pics will be up later The spawn of AndrewS 2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead 2016 Mini Countryman Cooper S All 4 2019 BMW R1200 GSA Rallye Sport |
Its OK I found one
Click image to enlarge 130's have feeling's as well you know |
Seriously !! Out of the thousands and thousands of pictures it had to be that one
Side rails aren't on it there because of the roof tent 2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead 2016 Mini Countryman Cooper S All 4 2019 BMW R1200 GSA Rallye Sport |
| harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309
Stupid question no doubt, but why are you sat there with no tyre on your rear wheel?
Pressures were let down for sand driving. The Mach5 rims dont have a very deep bead to hold the tyre on the rim. As a result the low pressures allow the tyre to move a bit and they deflate. If a few tight turns are required in these circumstances, occasionally the tyre will pop off the rim. The tyre was replaced with relative ease. 130's have feeling's as well you know
Im guessing on a side slope with a loaded roof-rack this could be quite a dangerous situation. Are those Mach 5 rims notorious for this problem or are they no worse than the normal LR boost alloys?
We pulled the car onto level ground then lifted it with an air jack, easy fix. They're 18" mach 5s, I think the tyre presure ran a little low on that wheel causing it to pop off
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
Nice roof tent Main Brian James Trailer Dealer for South West UK |
Excellent bit of kit very much appreciated
Sold
You sold his roof tent
