![]() | Home > Puma (Tdci) > Drip drip drip |
Wet headlining could be cracked roof gutters....
http://www.defender2.net/forum/topic5842.h...headlining As you have airconditioning it may be worth getting underneath and checking the drain teat if it is clogged and modifying it by cutting it if it is...... http://www.defender2.net/forum/topic14249.html?highlight=drain If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Gleaney Member Since: 03 Dec 2012 Location: Earth! Posts: 94 ![]() ![]() ![]() |
The guys water tested it and the alpine seal wasnt seated right. And I looked at the roof gutters and there's no cracks in there.
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Fill the gap with acf grease but i doubt that thats the cause of your problem! |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
My 12MY is also leaking into the passenger footwell. I can see a drip of water on the inside plate where the bolts go through to the bracket which now replaces the windscreen hinge.
Fortunately still under warranty so when the bad weather backs off, it will be a trip to the stealer. The previous owner kept the Landie in a garage so I suspect he never realised there was a problem. |
Gentlemen. No leaks. It's like a submarine now
