![]() | Home > Td5 > Replacing vent flap cables |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Having just stripped a dash to replace a bulkhead, I'm sure (without going in the garage to verify) that that cable goes into the lower part of the dash, when I took it off, I actually thought 'that looks a bit tricky to replace!
I'm about to go out for the morning, though I'd be happy to take pics of the dash and or see if there's a 'cheat' way of doing it. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Pics as always would be nice - thanks 1999 Defender TD5 110
Aww crap. I've only just sat down... I'll dig it out tomorrow. Totally busy and forgot.
Ahhhhhhhhhh no matter. 1999 Defender TD5 110
Watch this space, will jump in the garage in a bit
Right then, not gonna kid you, it's a bit of a big job. Either put a day aside to strip the dash entirely, or the easy option... go down your local bike shop and ask them for an off-cut of an inner brake or gear cable and attach it to the bit that you have at the lever end, I'd use a very small block connector...or solder it (as you're a 'Ham'
![]() If you need pics of the dash/flap end, let me have an email and I'll send you them. |
Thanks. I think it will be a fix job as the flaps dont appear to be operating as they should, they flaps appear stiff...
At the mo, I think the passenger side one is partly open and the drivers side open more. Will PM email address over in a mo and yup,I am a ham (2E0DHN) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
