![]() | Home > Puma (Tdci) > Grease nipples |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
Where are all the grease nipples located on a 2.4 puma. What is the recommended grease to use?
Mainly the prop shafts.
see http://www.defender2.net/forum/topic29299....rop+grease http://www.defender2.net/forum/topic27305....rop+grease http://www.defender2.net/forum/topic8258.h...rop+grease One or twice a year (more if wading). I just do mine once a year, and also when I'm changing lubricants on the gearbox and transfer boxes (something to do whilst you're waiting for the old oil to run out ![]() |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
Propshafts of a Puma don't always have nipples, some are sealed for life.
UJs (4) do still have them. |
![]() Models LD - Defender Title Defender Front and Rear Propshaft Grease Points Last Modified 30-MAR-2009 08:27 Category Noise/ Vibration Symptom 703000 Vibration Concerns Content Issue: Loose or missing front / rear propshaft grease nipples for Defender 07 MYonward vehicles. Action: If any propshafts are identified where the grease nipples are missing, then the propshaft should be replaced. Any cases where the grease nipples are in place but loose should be torqued to: 8Nm + 45degrees. |
Tried that one, but there are PropShafts with on nipples, sealed for life!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
They're the ones where not only did they forget the nipples, they also forgot the holes for the nipples!
