Home > Tdi > +2" lift kit brake pipe advice
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
I have just today bought a Terrafirma +2" lift kit from craddocks but totally forgot about brake pipes, do i need extra long brake pipes for this setup ( TF204 ) landy will be used for off roading / green laning aswell as every day car, what do you think Confused Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #393337 28th Jan 2015 4:12pm
roel
I would go for extended brake lines at least in the front I don't think it's needed in the rear.
I you want to save a little you might be able to lower the on the chassis and modify the plate on the caliper side. Roel
2003 90 Td5 (2009-now)
Post #393444 28th Jan 2015 9:47pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
What are you doing about your propshafts?
Post #393613 29th Jan 2015 12:59pm
jst
Llama 4x4 i use for all my pipes, excellent product. consider banjo fittings straight to caliper too. search for other thread on here about it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #393631 29th Jan 2015 1:23pm
Bearing in mind the relatively insignificant extra cost, and the realtively insignificant additional effort to fit, I would definitely fit extended hoses. Not worth the risk, especially if they are short you could well rip out both circuits in a single incident.
Post #393641 29th Jan 2015 1:44pm
cornish rattler
Why, i didn't think i needed to Smile Graham
Post #393704 29th Jan 2015 5:24pm
steventheplumber
Watch part six of a 4x4 is born, helpful info.
you can get plates from paddocks to extend your props as well
Post #393771 29th Jan 2015 8:06pm
