|  | Home > Technical > The MOT |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006    | Hours work tops. With a cuppa as well... | ||
|  27th Jan 2015 8:23pm |
| strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1407      |
 I had heard about it and just asked in my local main dealer. I was registered there and then, then received a 'membership card' through the post. It gives me a discount (can't remember how much sorry) on servicing, and as I say, a free MOT. www.landroverallegiance.co.uk - and sign up Euro-Leafing to infinity and beyond..... | ||
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6736      | Did you get no warranty when you bought it?
 You seem to have had a lot of niggly issues with this car    1988 90 Td5 NAS soft top  2015 D90 XS SW | ||
|  28th Jan 2015 10:55am |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | It does have a warranty yes and I've not even looked at the policy yet to look if it cover leaking seals, I suspect it probably won't
 The front, rear screens and wiper blades were all covered by the dealer as the warranty didn't cover them. Wheel Bolts and these advisories are the only outstanding items. When they supplied the vehicle the front brake pads would have had 7k left in them so really wouldn't have been covered. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) | ||
|  28th Jan 2015 1:25pm |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501      | Check the axle breather tube is not blocked before changing diff seal as a blocked breather will lead to an increase in pressure in the axle as it warms up which will have to vent somewhere.
 I changed a diff pinion seal twice on a previous defender before I worked this out  2005 Td5 90 XS Steve | ||
|  28th Jan 2015 7:11pm |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | We spoke to the local and very well respected specialist and his advice is to leave both for the time being.
 Not the 1st time I've tried to pay him to do work and he's said no. Hubby meanwhile has said the oil isn't on the bearing it's on something he's described as a hip joint and the oil is on the socket. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) | ||
|  28th Jan 2015 7:18pm |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501      | If it's leaking its Land Rovers way of telling you it's not empty yet    2005 Td5 90 XS Steve | ||
|  28th Jan 2015 7:32pm |
| Posting Rules
